Batch URL Downloader 3.2 & Viking Brothers 2 & Mystery Solitaire: Grimm's Tales
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Batch URL Downloader 3.2
Some download managers may be more complex than some users would like. "Batch URL Downloader" is one of the simplest applications of its kind, so it can prove to be a good alternative to overly-complex download managers. It enables you to save multiple files as part of the same job. Essentially, all you have to do is paste a list of URLs in the text field and then click the "Download All" button. The files will be saved in quick succession, and the job progress is displayed in the status bar.
If you need to download a large number of links and wish to avoid saving them individually, this application can certainly prove helpful. It can speed up the process of downloading a large number of files from a URL list.
The application includes "URL Grabber" and "Scheduler", supports single-threaded (one by one in order) and multi-threaded downloading. SSL/TLS and GZIP enabled web servers are also supported.
Key Features:
* Multi-threaded downloading
* Download scheduler
* SSL/TLS support
* GZIP support
* Low memory usage
* URL Grabber
* Support for downloading very large files
* Portability
* Editable output filename format
* Editable user agent string
Link
Game Giveaway of the day — Viking Brothers 2
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
Join Viking brothers Everand and Boromere as they set off on an all-new, humor-filled adventure to right wrongs, do good and keep their tankards filled with ale. This won't be easy, as a mysterious force is forging a path of destruction across Earth and Asgard! But Viking strength and valor have never failed and neither will the brothers!
Link
Game Giveaway of the day — Mystery Solitaire: Grimm's Tales
Dive into the infamous fairytale world of Hansel and Gretel from the Brothers Grimm and complete challenging solitaire layouts across 20 magical locations! Levels vary in complexity and provide hours of gameplay with solitaire challenges such as spider solitaire, pyramid, hearts, klondike, free cell, crescent, golf and many more. Regardless of game type, solitaire is an age-old game that never loses its flavor!
Link
mfG
Trapped
Kein Support per PN/Mail
