Perfect Hotkey 1.32
Keine Stimmen
trapped
Been thanked: 3 times
Perfect Hotkey 1.32
Beitrag von trapped »
Giveaway of the day — Perfect Hotkey 1.32
Perfect Hotkey will help to create and maintain a list of your hotkeys easily. You can customize hotkey categories and set which command goes with each hotkey. Some of them are internal Perfect Hotkey commands and the rest are Windows commands. The program will help you to manage repetitive tasks on your PC with high speed and minimal effort.
Why is it faster? Usually you open a program by clicking on the Start menu button, then clicking on All Programs. Your eyes search for the program icon, then you must click on it and only then the program will be launched. With Perfect Hotkey launching programs will take less time than usually.
Link
mfG
Trapped
Kein Support per PN/Mail
