Vidmore Video Converter 1.3.8
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Vidmore Video Converter 1.3.8
If you’re a movie or TV show collector, then you must own abundant videos, music videos, clips from TV shows, home movies, animation clips, and much more. Then, a tool that can help you convert the videos into a digital format is of great necessity. Vidmore Video Converter must come in handy. Not only is Vidmore Video Converter one of the best video converter programs, but also it boasts video editing capabilities and other stunning features. Using Vidmore Video Converter, you can convert both video and audio files to MP4, MOV, VOB, MKV, FLV, AVI, MP3, OGG, as well as devices like iPhone, Apple TV, iPad, Samsung, Wii, PS4, etc. The conversion is ultra-fast while maintaining the original quality of your files.
One great feature is before you convert the file, you can edit and customize the file with its built-in video editor, including trimming, cropping, rotating, watermarking, adding effects & filters, adjusting brightness/saturation/hue, and more. Aside from that, the video converter software allows you to make your own movies with background music, create split-screen videos provided with numerous templates, make animated GIFs, enhance the video quality, compress the video size, and more.
Its interface is super simple and intuitive that makes you quicky get the conversion job done even if you’re a beginner. More importantly, Vidmore offers a comprehensive user guide and great support team in case you encounter any problem.
Special Offer: 40% Discount for Vidmore Video Converter (Lifetime/3 PCs)!
Link
mfG
Trapped
Kein Support per PN/Mail
