DearMob iPhone Manager 5.3 (Win&Mac) & WinExt Pro 25.0
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — DearMob iPhone Manager 5.3 (Win&Mac)
DearMob iPhone Manager will be your must-have helper for iPhone switch, safe backup, and daily management. If you intend to get a new iPhone or upgrade to iOS 15, we suggest you to try this software. It is designed for seamless iOS/iPadOS data backup and transfer, with handy built-in tools to encrypt, convert and selectively restore content. Say "No" to iTunes/Finder and iCloud limits, it simplifies the way you import, export, and manage iDevice with custom options and no data erasing. DearMob gives you full management of iDevice files, incl. photos, music, videos, contacts, SMS, podcasts, e-books, calendar, bookmarks, ringtones, and apps.
What’s new?
Added support for iPhone 13/13 Pro/13 Pro Max/ 13 Mini.
Added support for iOS 15, iOS 15.0.1 and iOS 15.0.2; Added option to toggle Wifi connection in settings.
Added option to export edited photos only, or, to export both the edited and original photos in settings.
Highlights of DearMob iPhone Manager:
Allows you to delete unwanted photos and video in iPhone camera selectively or in batch.
Enables two-way file transfer between iPhone and computer selectively. Fully back up or restore iPhone file.
Manage music/playlist, photo/albums, contacts: export, add, create, modify, delete , rebuild, edit, etc.
Batch export files by your selection, by day, week, month, year, by artist, album, music list, search, by folder.
Convert HEIC to JPG, Live photo to a video & still image. Export contacts as VCF/PDF/TXT/HTML.
Import & convert video, music, e-books to be compatible with iDevice; auto-rotate video to fit iOS full screen.
Encrypt local files or iOS backup; offers option to export iOS files with encryption, Use iPhone as USB drive.
Lightning fast and stable. Transfer 100 4K photos in about 8 seconds. Handle 10000+ photos without freezing.
Bonus: Digiarty also provides you a unique chance to get Lifetime Full License at 75% off. Valid for 48 hours only!
Link
Giveaway of the day — WinExt Pro 25.0
A Powerful Utilities Kit for Windows:
Fix Registry Issues.
Clean up System Junk.
Protect Your Privacy.
Improve Performance, Speed and Stability.
Find Duplicate Files.
Shows Larger Resources (Folders and Files).
See More Information of Recently Accessed Resources.
Monitor Windows Activity.
Make Batch Operation on Multiple Resources.
Disable Unwanted Context Menus.
Automatically or Manually Synchronize Resources.
Run Trusted Programs Without UAC Prompt.
Please note: 1 Year Single License (1 PC) is included in this version. Click here to get a VERY BIG discount for other advanced licenses on the promotion day!
Link
mfG
Trapped
Kein Support per PN/Mail
