abylon CRYPTDRIVE 20.60.09.2 & VideoProc Converter 4.4 (Win&Mac) & Fish Story
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — abylon CRYPTDRIVE 20.60.09.2
abylon CRYPTDRIVE creates so-called container files, which are secured with the known encryption algorithms AES or Blowfish. Only if the corresponding key was used, the secured data show up in the file explorer. A key password can be entered with the keyboard, as well as by a chip card, USB stick or certificate. When Cryptdrive is opened, the contained files are displayed in the assigned drive and can be edited.
Link
Giveaway of the day — VideoProc Converter 4.4 (Win&Mac)
VideoProc Converter (the former name VideoProc) is a simple yet strong software combo of video/audio converter, DVD ripper, video editor, video downloader, recorder and video to GIF maker. It works well with any videos shot with GoPro, DJI, iPhone, Android, camcorder, or other 4K cameras (DSLR or mirrorless). By fully utilizing the power of Intel Core, NVIDIA, and AMD, it can efficiently process 4k videos, HDR, 3D and 360 degrees VR videos, large-sized videos without freezing and crashing. Meanwhile, keeping a good balance between size and quality.
New Features:
-Added new output profiles for iPhone 13/Pro/Pro Max/mini; Support Windows 11 and MacOS 12.
-Added the feature of estimating video size and let users know the final size before re-encoding and exporting.
Highlights:
Convert: any old/new DVDs, videos, audios to any video audio formats & devices, 3D to 2D, totally 420+ profiles.
Compress big 4K/8K/HDR/HD videos with highest quality; Downscale 4K to 1080p/720p, vice versa. GIF to video.
Download video, music, playlist, live streaming from 1000+ sites. Add, search SRT subtitle for movie /TV series.
Abundant editing features: cut, split, crop, merge, resize, reframe, add effect/subtitle/watermark, make Gif, etc.
Repair: stabilize, denoise, defisheye, rotate/mirror, slow down or speed up footages, force A/V sync, etc.
Adjust: customize bit rate, resolution, GOP, encoding mode, 4K to 1080/720p and more.
-Record: capture desktop/iOS screen/live video; record video with webcam, make PIP video, apply green screen.
-Easy-to-use, just drag-and-drop. No.1 fast video processing speed. Support batch downloading and conversion.
Bonus: Digiarty also provides you a unique chance to gain Lifetime Full License at 70% off discount.
Link
Game Giveaway of the day — Fish Story
This story took place somewhere in the tropics. In the sky, near a large lagoon, glowing lights appeared, so bright that they became visible even under water. And then some objects began to fall from the sky...
Help the brave fish unravel the story of the lights!
Link
mfG
Trapped
Kein Support per PN/Mail
