UnHackMe 13.20 & Apowersoft Background Eraser 2.3.11 & Tofu Escape
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — UnHackMe 13.20
UnHackMe wurde zunächst als Anti-Rootkit Software kreiert, doch zurzeit hilft es euch beim Kampf gegen Google Search Redirects, Rootkits, Trojanern, Hintertüren, Viren, Würmern, Adware, Spyware, Keyloggern und weitere unerwünschten Programme. Dieses Tool scannt Windows-Startup, Dienste und Treiber, testet Host-Dateien und DNS Einstellungen sowie alle weiteren verwendeten Dateien mit Hilfe von Virustotal, der programmeigenen Datenbank.
UnHackMe erkennt und löscht diverse Malware-Arten:
Anti-Rootkit (Google Redirecting Fixer).
Anti-Malware, Anti-Trojaner, Anti-Bot.
Anti-Adware, Anti-Spyware.
Popups;
Potentiell unerwünschte Programme;
Unerwünschte Prozesse;
Rootkits;
Trojaner;
Spyware;
Keylogger.
NB: Lebenslange Lizenz.
Link
Giveaway of the day — Apowersoft Background Eraser 2.3.11
Apowersoft Background Eraser is an awesome software that helps to remove background from image automatically without any hassle. In just a few seconds, you can get your precise cutout with transparent background and further edit it. Solid colors and well-designed templates are available for you to create your own pictures. It’s available for Windows, Android and iOS version.
Apowersoft Background Eraser is very convenient and simple wherein beginners can easily get started without reading tutorials. No matter it is a person, car, product, logo, or anything else, you can always cut it out from the image precisely with just few clicks. As long as you upload your image, this magic tool will automatically separate the foreground from the image, making the image background transparent. That means users no longer need to select the area manually.
Key Features of Apowersoft Background Eraser:
- remove image background automatically in few secs
- one click to change background
- support removing multiple images at once
- support to make product photo and ID photo
- massive designed templates for holiday and scenery are available
- support basic photo editing features, like crop, flip, and beauty, etc.
- support removing unwanted objects
- save edited images in original resolution on PC
- support keep and remove tool to manually edit details
NB: The license provides 300 images.
Link
Game Giveaway of the day — Tofu Escape
Tofu Escape is a platformer only for the most agile players.
Scientists conducted experiments and reagents got on someone's lunch, as a result of which tofu gained intelligence. After looking around tofu decided to run, but the laboratory is very well protected from leaks, so there are many obstacles and traps on the way.
A platformer game with a side view, the purpose of which is to overcome obstacles to pass levels of varying difficulty. Spikes, saws, flying projectiles, moving platforms and much more are waiting to finish you off in the game Tofu Escape.
-Simple and pleasant graphics
-hardcore gameplay
-60 levels, 3 locations
-gamepad support
-memorable music
Link
mfG
Trapped
Kein Support per PN/Mail
