TwistedBrush Paint Studio 3.03 & DVDFab Blu-ray Copy 12.0.5.6 (Win&Mac) & Test Motorbike
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — TwistedBrush Paint Studio 3.03
Providing painting and drawing with natural media brushes, TwistedBrush Paint Studio makes no compromises in offering the best of the TwistedBrush painting engine. Presented in an interface that's perfectly suited for creation of new art work using expressive brushes from thick wet oil paints and fluid watercolors to slick oil pastels and fine airbrushes and everything in between.
Over 120 of the very best natural media brushes available anywhere in these general categories: Acrylics, Airbrushes, Basic Brushes, Blenders, Charcoals and Chalks, Crayons, Erasers, Markers, Masking Brushes, Oil Paints, Oil Styles, Palette Knives, Pastels, Pencils, Pens, Watercolors.
Link
Giveaway of the day — DVDFab Blu-ray Copy 12.0.5.6 (Win&Mac)
DVDFab Blu-ray Copy is the fastest Blu-ray copier that helps copy any Blu-ray to any blank Blu-ray disc and even DVD disc, or copy to your computer for backup. The program will make 1:1 copies, as well as compress movies to fit less capacious types of BD discs. The backups will play on systems without HDCP monitors or video cards. DVDFab Blu-ray Copy can remove all the copy protections of your Blu-ray disc, enabling you to create copies for backup purposes. It allows you to customize numerous audio and video settings prior to conversion and it is very easy to work with.
The user with the best improvement idea will be rewarded with a 1-year license for DVDFab Player 6 Ultra. Please use IdeaInformer Widget.
Link
Game Giveaway of the day — Test Motorbike
Test Motorbike is game is very addictive and realistic. If you want to experience extreme motorcycle racing game,
this is the game that you should try. Riding a motorbike is definitely more challenging than even the most extreme
car driving simulator. That’s because you have to control everything at once: your direction, the speed, and how you throttle.
To succeed as drift racer, you must give your 110%
Features:
Realistic and immersive game graphic & sound.
Unlock various challenges and tracks.
Try your hand at riding low cc scooters and turbo bikes
Perform awesome motorcycle stunts on your bikes.
Intuitive and response game control.
Link
mfG
Trapped
Kein Support per PN/Mail
