Vidmore Screen Recorder 1.1.52 & Puzzle Spain 2022
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Vidmore Screen Recorder 1.1.52
Vidmore Screen Recorder is a professional but easy-to-use screen capture tool with superb and highly-customized recording features. It's capable of recording any part of your computer screen and capturing audio from system sound, microphone, or both. Apart from its fundamental video and audio recording functions, it can help you save gameplay highlights, capture your webcam to create picture-in-picture video effects, and record the screen on your iPhone.
While recording, you are provided with various editing tools, such as making annotations. Once your recording is over, you can preview the recording and cut the unwanted part, and save the essential part. This tool lets you export the recorded file to MP4, AVI, MOV, MP3, etc. Plus, you can share it to YouTube, Facebook, Vimeo, or other platforms after exporting.
Special Offer: 40% Discount for Vidmore Screen Recorder (Lifetime/3 PCs)!
Link
Game Giveaway of the day — Puzzle Spain 2022
Puzzle Spain 2022 is a game on the theme of the city and sights of Spain, a puzzle game in which you do not need to drag and drop elements, just swap them by clicking on them with the mouse. The game has 12 levels, each puzzle consists of 45 elements. In this version, buttons have been added to the panel: sound, mute, hint, next level and exit to the main menu. With the right decision, you will automatically go to the next level, but if the passage of the level caused you difficulty, then you can skip it. The game has a choice of levels and you can start playing from any level. There is a help button on the panel, click on it if the game caused you a problem and you don’t know where to put the next element, when you click on the button, a full image will appear, which will automatically disappear after a certain period of time. The difficulty of the game is medium.
Link
mfG
Trapped
Kein Support per PN/Mail
