Fast Video Downloader 4.0.0.29 & iBoysoft DiskGeeker 3.0 & Animals Of The World
trapped
Beitrag von trapped »
Giveaway of the day — Fast Video Downloader 4.0.0.29
Fast Video Downloader is software that allows you to download videos from video streaming websites. It can also download videos from sites that use MP4, AVI, FLV, WebM, WMV, 3GP, and MP3 file format or host videos. Fast Video Downloader can download live streams from the internet and livestream.com.
You can search videos directly in the application and add them to the download list.
It has a built-in scheduler to schedule the download of the videos. You can also download multiple videos simultaneously.
HD Video Support:
You can download 8K, 4K Videos with this downloader. 4K and 8K resolution videos if available on the website then you may download with the select video quality option.
Video Converter:
It can also convert videos to iPhone, iPad, iPod, Android, PSP device compatible format. It can extract audio (mp3) from the video. It can change the resolution of the video without changing the video format.
Screen Recorder:
Fast Video Downloader has a feature to record your computer screen with a microphone and system audio. You can select the area of the screen to record. You can also include/exclude Speaker and /or Microphone audio in your screen recording. No limit for screen recording. You can also specify the stop time after which the recording will stop automatically.
Features and Benefits:
• Download Unlimited Videos and playlists from 1000+ video sites
• Search video directly from the application
• Download Live Stream videos
• Download Full HD video
• Set Video Download Schedule
• Unlimited multiple downloads
• Convert Videos to MP4, AVI, WMV, MP3, iPhone, iPad, and more
• Manage your download history of videos.
• Free Application updates & submit feedback for failed videos.
• Screen Recorder with microphone and system audio setting.
Link
Giveaway of the day — iBoysoft DiskGeeker 3.0
iBoysoft DiskGeeker is an all-in-one disk management tool designed to help Mac users achieve cross-platform disk use, optimize system performance, ensure data protection and security as well as raise work efficiency. Its main functions are listed below:
1. BitLocker for Mac and NTFS for Mac: provide the permission to read and write to NTFS drives and BitLocker encrypted drives.
2. Disk encryption and unlock: encrypt and unlock disks with BitLocker or FileVault.
3. Disk diagnosis and repair: support disk check and repair to lower the risk of data loss.
4. USB Defender: protect USB drives from being attacked by viruses via setting USB Defender.
5. Disk clone: quickly create a 1-to-1 copy of your disk to back it up.
6. macOS Optimization: clean junk files from the startup disk and selectively remove unwanted files from partitions or volumes to boost Mac performance.
7. Drive management: manage external hard drives, USB flash drives, or network drives.
Link
Game Giveaway of the day — Animals Of The World
AnimalsOfTheWorld is a wild animal themed puzzle game in which you don't have to drag and drop elements, just swap them by clicking on them with the mouse.
The game has 12 levels, each puzzle consists of 45 elements. In this version, buttons have been added to the panel: sound, mute, hint, next level and exit to the main menu. With the right decision, you will automatically go to the next level, but if the passage of the level caused you difficulty, then you can skip it. The game has a choice of levels and you can start playing from any level. There is a help button on the panel, click on it if the game caused you a problem and you don’t know where to put the next element, when you click on the button, a full image will appear, which will automatically disappear after a certain period of time. The difficulty of the game is medium.
Link
mfG
Trapped
Kein Support per PN/Mail
