ExplorerMax 2.0.3.30 & Abelssoft Recordify 2022 & Mythic Heroes
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — ExplorerMax 2.0.3.30
ExplorerMax is an efficient chrome-styled file manager for Windows users.
Key features:
1. Tabbed Browsing: The chrome-styled tabbing feature enables you to open multiple files at the same window, and add bookmarks with a drag-and-drop.
2. Clear TimeLine: ExplorerMax can classify your browsing history into four groups (Today, Yesterday, Latest Week, Latest Month) to help you manage your work efficiently.
3. Quick Search: As long as you enter the keyword in the search box and set the target file type, you can get grouped results in a second.
4. Dual Pane: The dual pane feature allows you to switch and interact between two tabs.
5. Skin Preferences: When you change the accent color for the system, ExplorerMax will respond to the modification quickly and display the stylish interface
Link
Giveaway of the day — Abelssoft Recordify 2022
Recordify works like live recorder and saves every song as a single MP3, WAV or FLAC file.
Supports different streaming services
Recordify was developed to save music from all the popular music streaming services in high quality.
Record as „Stereo Mix“
With the additional recording function "Stereo Mix", you can also record anything else that is being played on your PC speakers.
Download Music
No matter if it's a single song, or an entire playlist – Recordify can download all songs to files.
RECognition
Just let your playlist play, while Recordify recognizes every single song and saves it in a correctly named file.
Quality
Music quality is dependent on the streaming service used. Enthusiasts use high quality settings of up to 320 kbps.
Formats
The music downloaded by Recordify can be saved as MP3 or WAV file or in the premium quality file format FLAC.
Cassette recorder reloaded: Stereo-Mix
Using Recordify, you can not only save music from streaming services, but also everything else that is played with your audio speakers! With the "Stereo Mix" recorder you have a start/stop button to tape-record and save everything.
Link
Game Giveaway of the day — Mythic Heroes
The program archive includes the readme file with the further instructions!
Enter the Ascension Realm in the latest idle RPG from IGG: Mythic Heroes. Summon and forge friendships with your favorite heroes from myth and legend including Thor, Loki, Hades, and Artemis! Explore the ancient stories of the world from the depths of Atlantis to the heights of the Kunlun Mountains. Your journey in the Ascension Realm awaits, Summoner!
The gift package worth $150 will include:
- 1 x SSR Custom Voucher
- 10 x Standard Summon Scroll
- 1000 x Diamonds
Link
mfG
Trapped
Kein Support per PN/Mail
