MobiKin Doctor for Android 4.2.53 & A1RunGuard Premium 1.3.2022
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — MobiKin Doctor for Android 4.2.53
The best Android data recovery software to help you recover deleted contacts, text messages or call logs on Android phones and tablets. The best Android file recovery tool to retrieve photos, videos, music files or documents from overall Android devices.
MobiKin Doctor for Android Lifetime License 50% discount for GAOTD users.
Link
Giveaway of the day — A1RunGuard Premium 1.3.2022
A1RunGuard is a bulletproof blocker for unwanted programs + password protecting any executable+additional Anti-Ransomware protection.
A1RunGuard can prevent some Ransomware attacks.
Ransomware often uses legitimate programs that may be found across all Windows versions for various destructive operations. This technique allows ransomware to avoid detection by the antivirus software.
A1RunGuard intercepts the launch of these programs, but instead of completely blocking them, A1RunGuard investigates the command lines of the program and fires the alarm only if a dangerous combination occurs.
A1RunGuard can protect any executable file from running by a password.
It allows specifying the main password or a special password for each program.
A1RunGuard can block any unwanted process by the file name or the full path.
A1RunGuard does not slow down the overall performance of a computer. It does not install system drivers, does not use real-time monitoring, not change the system files.
A1RunGuard is fully compatible with Windows 11/10/8/7/Server (64-bit and 32-bit). It is compatible with any antivirus.
A1RunGuard's free version is available for commercial usage.
Link
mfG
Trapped
Kein Support per PN/Mail
