Hi-Q MP3 Recorder Pro 4.2.2.20
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Hi-Q MP3 Recorder Pro 4.2.2.20
If you can hear it you can record it with Hi-Q MP3 Recorder Pro. MP3 sound recorder and mp3 voice recorder Hi-Q MP3 Recorder Pro records MP3 from any device installed on your system.
Hi-Q MP3 Recorder Pro recors to high quality MP3 and you can edit mp3 files with the built-in audio mp3 editor.
You can cut, copy, paste, trim, split, join, and apply professional audio effects to mp3 files.
You can apply audio effects to audio such as volume gain or reduction, noise reduction, reverb, equalization, pitch, and many more...
Main features:
1. Easy to use mp3 audio recorder.
2. Record directly to high quality mp3.
3. Cut, split, trim, join mp3 files with built-in audio mp3 editor.
4. Reverb, noise reduction, equalization, and 20+ professional audio effects.
5. Convert to 10+ different formats.
Extra features:
1. Real-time audio spectrum frequency analyzer.
2. Audio editor with multiple segments selection.
3. Extra professional effects.
Hi-Q MP3 Recorder Pro is a complete audio capture, editing, and converting suite.
Link
mfG
Trapped
Kein Support per PN/Mail
