iBoysoft MagicMenu 2.0 & Photo Slideshow Creator Pro 4.2.2.20 & Magician Of Fire
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — iBoysoft MagicMenu 2.0
iBoysoft MagicMenu is a multifunctional Mac right-click enhancer designed to help users customize the Mac right-click menu to improve work efficiency. As a practical Mac right-click booster, this utility plays the role of a control panel and permits users to take better control of the Mac right-click menu by adding or customizing new file creation, file transfer, quick access, screen recording shortcuts, and more to their right-click menus. It stands out for these premium features:
- Create different types of new files including TXT, RTF, Doc, XLS, WPS, PPT, Keynote, Markdown, Numbers, Pages, and the like.
- Import blank or pre-edited template files as shortcuts from local folders.
- Enables users to add folders to the Move To menu and quickly move a file to a target path with a single right click.
- Permits users to add a folder shortcut to the Copy To menu and quickly copy files to a location.
- Offers quick access to files stored on Downloads, Documents, Pictures, Desktop, and Music, apps users frequently use without launching it in Finder, and webpages users frequently browse without saving them as bookmarks.
- Presents many useful features in Function Library, including screen recording, file path copying, hidden file listing, etc.
- Supports sorting functions and categories.
Link
Giveaway of the day — Photo Slideshow Creator Pro 4.2.2.20
Photo Slideshow Creator Pro is perfect to create amazing slideshows with music quickly and easily. With Photo Slideshow Creator Pro, you add the photos, and right away you can preview and create your slideshow.
With Photo Slideshow Creator Pro slideshow maker with music you create 4K and HD slideshows effortlessly. The program has 50+ different transitions including fade-out, slide across, 3D effects, pixelation, and 40+ different others.
You can add and order photos easily by drag & drop. With this picture slideshow maker you can create a picture slideshow as easily as you might organize photos in an album.
You can add multiple audio tracks to be the soundtrack of your slideshow, you can apply fade-in and fade-out effects to the soundtrack, you can randomize slides and transitions in one click, and you are offered other useful shortcuts as well.
Main Features:
1. Slideshow creation in a few clicks
2. 4K and HD photo slideshow software
3. 50+ different transitions including 3D effects, blur, pixelation, stretch, flash, and many more...
4. User interface entirely drag & drop operated making it a very easy to use video slideshow maker
5. Wizard help to select output format.
6. Support for all most important formats: MP4, WMV, MOV, 3GP, AVI, MPG, MKV
7. WYSIWYG Preview Feature: You see exactly what your slideshow will look like after created.
Extra Features:
1. One click shortcuts to randomize transitions and to randomize slides
2. One click shortcuts to randomize transitions
3. Ability to upload your slideshow to YouTube
If you're looking to create amazing sileshows with music Photo Slideshow Creator Pro can get the work done quicly and easily.
Link
Game Giveaway of the day — Magician Of Fire
You are a fire mage, and your task is to defeat the powerful necromancer and his army in their magical lair!Show them the power of your fire magic.Crowds of different enemies, treacherous traps, heart pumping action and bosses are waiting for you!The game features 17 levels and 6 bosses.
Management:
WASD-Move
Space-jump
LMB-Simple attack
RMB-Strong impact
Link
mfG
Trapped
Kein Support per PN/Mail
