AVS Video ReMaker 6.7.2.263 & CD DVD Blu-ray Burning Studio 3.8.8.80 & Loveless Cat
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — CD DVD Blu-ray Burning Studio 3.8.8.80
What can you do with CD DVD Blu-ray Burning Studio? Long story short: anything you need, i.e. you can burn files and folders to any kind of disc, burn image files on discs, burn Audio CDs from digital sources like MP3, APE, FLAC, WAV or WMA, or create image file from disc, clean a rewritable disc, copy a disc, create image file from folders/files, convert image files, or view disc/drive information with a single click.
Doesn't stop there: With this dvd burning software you can create video DVDs and Blu-ray with high quality video, even 4K and HD if you use them as source.
Audio CDs created with CD DVD Blu-ray Burning Studio will be reproduced by any device. MP3 CDs and DVDs burned with CD DVD Blu-ray Burning Studio will also be reproduced by any device. Video DVDs and Blu-ray will also be reproduced by any device. The program gives you a few options on video encoding but mainly it does the necessary conversions.
Certainly you can find more advanced options cd burning software and blu ray burning software out there but with this range of action and whithin this price range you're well served with CD DVD Blu-ray Burning Studio. Plus the user interface could not address the tasks more simply. There is no complication whatsoever. Not so many options but easier to use then any other.
Main features:
1. Allows you to burn MP4, MKV, AVI, VOB, FLV, MOV, ISO formats on media discs.
2. Supports all important formats/discs.
3. Supports disc spanning.
4. Excellent for manual data-backup.
5. Can burn/create ISO files.
6. DVD types supported include DVD-9, DVD-5, DVD-R/RW, and on top of that, you get BD-R, BD-RE, BD-25, BD-25, BD-50, and BD-100.
Extra features:
1. No other software breaks media burning tasks so perfectly apart in one easy-to-use interface.
2. Size occupied on disk preview.
3. Converts all types of media to CD DVD Blu-ray compatible content.
If you're looking to do media burning related tasks on CD, DVD, to Blu-ray discs, audio, video, data, ISO creation and burning, disc erasing, and more for a lot less you would pay elsewhere and still have reliability and all the important bells and whistles, does sound like a cost-effective deal.
Link
Giveaway of the day — AVS Video ReMaker 6.7.2.263
AVS Video ReMaker is a super-fast video editor to capture, edit and save video without re-encoding. Cut, trim, delete unwanted parts, change scene sequence, merge several video files with similar parameters. Make better videos adding amazing transitions, create a stylish menu and share your masterpieces with everyone.
Link
Game Giveaway of the day — Loveless Cat
Embark on an incredible journey in search of new friends! After many dates, Vasily, the cat, finally meets Mila. During their stroll, spring suddenly disappears and it becomes cold, and so they set off to figure out why. Prove that you can withstand all the tests and prove to your new friend that you are a real March cat. Unravel the mystery of the lost spring!
Features:
* Many exciting levels that will keep you entertained;
* Good physics;
* High quality, beautiful graphics;
* Suitable for children and adults;
* Great background music.
Link
mfG
Trapped
Kein Support per PN/Mail
