Coolmuster Mobile Transfer 2.4.52 & Revival Of Life
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Coolmuster Mobile Transfer 2.4.52
Habt ihr keine Ahnung, wie ihr Daten von einem alten Telefon auf ein Neues kopieren könnt, da sie von verschiedenen Herstellern stammen? Mobile Transfer ist ein hervorragendes Tool, mit dem ihr Daten problemlos von einem Gerät auf ein anderes übertragen könnt.
Bitte beachtet: Das Tool beinhaltet eine Jahreslizenz.
Link
Game Giveaway of the day — Revival Of Life
The game reflects the "struggle" between spring and winter. At each level, you will attempt to achieve a complete transformation of the environment from winter to spring (from still ice to fresh flowers) ....You play as one of the "daughters" of spring. She will walk through all the frozen platforms, in the end they will be transformed and freed from ice and snow. Also, you need to defrost ponds, mills and trees.The more you release the platforms from the winter, the less snow falls, and if everything is released, then the snow stops completely. You must collect the solar balls (the number of which can be seen in the form of butterflies flying around the "daughter" of spring).Solar balls can be thrown at the "servants" of winter and they will melt. When all platforms are released, the portal will open, and you will enter.
To throw balls = use keys "C" and "V"
Cubes of ice can be destroyed = keys "Z" and "X"
Move = cursor arrows
Home and End keys = game speed selection
Alt+F4 = Exit
Link
mfG
Trapped
Kein Support per PN/Mail
