Audials Music 2023 SE & WonderFox HD Video Converter Factory Pro 25.6 & Space Beauties
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Audials Music 2023 SE
A music streaming recorder for all services. Downloading songs from many other popular services has never been easier. A music manager for organizing saved songs is also on board.
Link
Giveaway of the day — WonderFox HD Video Converter Factory Pro 25.6
WonderFox HD Video Converter Factory Pro is a program of the first batch supporting HD video conversion. Supported by WonderFox exclusive video encoding technology, HD Video Converter Factory Pro stands out from varied HD video converters that will achieve a higher quality of output.
Not only has the latest version been added screen recording, GIF making and other features, but also the video editing function has been greatly enhanced, supports cutting, clipping, adding special effects, watermarking and more.
Main Features:
Supports hardware encoding for NVIDIA NVENC, CUDA, and Intel HD Graphics hardware acceleration tech that contributes to high speedup.
Converts HD video to general video and reduces video size without quality loss.
Converts SD video to HD video (improves video quality with advanced high-definition video encoding core).
Downloads video in 8K, 4K, 1080P, 720P, 480P from 300+ sites.
Converts audio files and has a built-in ringtone maker.
Has A Built-in editor (Merge, Subtitle, Crop, Clip, Rotate, Volume, etc.)
Supports multi-language interfaces, such as English, French, Spanish and so on.
Record screen with ease.
WonderFox HD Video Converter Factory Pro Lifetime (1 PC). Only $19.95 (Normally costs $39.95).
WonderFox HD Video Converter Factory Pro Family Pack (3 PCs). Only $54.95 (Normally costs $79.95).
HD Video Converter Factory Pro+WonderFox DVD Ripper Pro Golden Pack. Only $29.95 (Normally costs $69.95).
Link
Game Giveaway of the day — Space Beauties
Space Beauties is a slightly challenging puzzle game with 35 pieces and 12 playable levels. In the game, you need to swap tiles in places to complete the image, as all the fragments will stand correctly, you will receive a notification that the game has been completed, and after 5 seconds you will move to a new level. In this version, there is no transition to a new level if you have not completed the current level.
The game includes one hint with which to simply start the game, the lower right fragment is marked with the "GameREA" logo. You won't be able to start the game from any level either. When you pass the level, the password for this level will be written at the bottom of the panel, from which you can start the game if you enter it on the passwords tab, which is located in the menu. The game is colorful and we hope you enjoy this format. Good luck to everyone in the game.
Link
mfG
Trapped
Kein Support per PN/Mail
