MG Easy Desktop Organizer Basic 4.0.4.155 & Coolmuster Data Recovery 2.1.18 & Falco Ball 3D
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — MG Easy Desktop Organizer Basic 4.0.4.155
Most of us keep our frequently used files, folders, and application shortcuts for quicker access. Most of the time, we will end up with a messy, confusing desktop. MG EDO, helps you to have access to your files, folders, and shortcuts, while you have a clean and organized desktop.
You can create an unlimited number of windows on your desktop, and show or hide them as you need. Easily keep unlimited files, folders, and shortcuts categorized by your style just by drag and drop them over the windows. Each window comes with a built-in search tool, which makes you able to find your desired file or folder easier and faster. Furthermore, you can manage your desktop wallpapers/backgrounds directly through the software. Also, you can enjoy downloading free high quality (HD) desktop wallpapers from the MSTech Global website.
Link
Giveaway of the day — Coolmuster Data Recovery 2.1.18
Für viele Menschen kann Datenverlust eine große Katastrophe bedeuten, besonders wenn ihre Dateien nicht regelmäßig gesichert werden. Coolmuster Data Recovery hilft euch, ein sorgenfreies digitales Leben zu führen!
Features:
Wiederherstellen von über 550 Formaten inklusive Fotos, Videos, Musik, Dokumente, Emails, .zip, usw.
Wiederherstellen von gelöschten, formatierten oder nur teilweise verfügbaren Dateien.
Retten von Daten auf internen und externen Datenträgern.
30% OFF auf alle Coolmuster Produkte mit dem Code COOL-KICV-HHTU
Link
Game Giveaway of the day — Falco Ball 3D
Falco Ball 3D is a game where you have to keep the ball in the air as long as possible. In the game you will find pleasant music that will help you focus on the gameplay. Set new records and improve them in Falco Ball 3D.
Control: Mouse.
Link
mfG
Trapped
Kein Support per PN/Mail
