20 Handmade Fonts & OCR Reader 2.2 & Cranks Rescue A Planet
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — 20 Handmade Fonts
Some wonderful fonts with a unique, detailed and handmade look. These fonts look amazing in all caps with a wide-set spacing if you want to try a classy look or beautiful on its own in capital and lowercase letters for something completely timeless. Perfect for gorgeous logos, displays, headers, invitations, save the dates, weddings, titles, web layouts, and branding, etc.
Link
Giveaway of the day — OCR Reader 2.2
Vovsoft OCR Reader is an image to text converter program that allows you to extract text from PNG, JPEG, TIFF, WEBP, and BMP files using Optical Character Recognition. This software is basically a text reader from image.
While there are many OCR tools available online, some prefer a dedicated desktop tool instead. The best part of the program is that the conversion is done completely offline. You are the only controller of your private data. No image file is sent to internet in any case.
This small and lightweight OCR tool can easily digitize image files and scanned documents on your laptop or desktop computer. It can scan documents using TWAIN and WIA scanner protocols. This application utilizes Tesseract OCR engine, which supports more than 100 languages. In order to increase accuracy, it uses a neural network (LSTM) based OCR engine which provides line recognition, but also can recognize character patterns.
You can create a selection box to recognize a specific area in your document. To do this, all you have to do is click on the image and drag the mouse to create a rectangle. Thus, the program will recognize only the region you selected. This will provide a more accurate conversion and speed up the process.
Link
Game Giveaway of the day — Cranks Rescue A Planet
A little old man is trying to save his innocent planet from being taken over by a villain named Gnumanikus. Help him in this difficult endeavor. You have three characters to play as, each with unique abilities. Use them to overcome obstacles on the way to capturing Gnumanikus and rescuing a dying planet.
Link
mfG
Trapped
Kein Support per PN/Mail
