Benutzung von alternativen Fernbedienungen
[MCP]
Beitrag von [MCP] »
Wie im Beitrag:
https://neutrino-images.de/board/viewto ... 11#p40411/
angekündigt, hier jetzt eine Möglichkeit der Anwendung für gewonnene Erkenntnisse.
Die ursprüngliche Schaltung (Arduino Nano V3, KY-022) bleibt bestehen, wird aber um eine IR-Sendediode KY-005 erweitert.
Die SFH409-2 ist dabei nur durch die KY-005 zu ersetzen. IROUT wird mit Pin 3 vom Arduino Nano V3 verbunden.
Das neue Programm sieht jetzt so aus:
main.cpp
 *  Interrupt.cpp
 *  Receives IR protocol data by using pin change interrupts and no polling by timer.
 *  !!! This WILL NOT work for all protocols.!!!
 *  Tested for NEC, Kaseiko, Denon, RC6, Samsung + Samsg32.
 *  To disable one of them or to enable other protocols, specify this before the "#include <irmp.hpp>" line.
 *  If you get warnings of redefining symbols, just ignore them or undefine them first (see Interrupt example).
 *  The exact names can be found in the library file irmpSelectAllProtocols.h (see Callback example).
 *  Copyright (C) 2019-2021  Armin Joachimsmeyer
 *  armin.joachimsmeyer@gmail.com
 *  This file is part of IRMP https://github.com/ukw100/IRMP.
 *  IRMP is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/gpl.html>.
#include <Arduino.h>
 * Set input pin and output pin definitions etc.
#include "PinDefinitionsAndMore.h"
#define IRSND_IR_FREQUENCY 38000
#define IRMP_PROTOCOL_NAMES 1  // Enable protocol number mapping to protocol strings - requires some FLASH. Must before #include <irmp*>
#define IRSND_PROTOCOL_NAMES 1 // Enable protocol number mapping to protocol strings - requires some FLASH.
#define IRMP_USE_COMPLETE_CALLBACK 1       // Enable callback functionality
#define IRMP_ENABLE_PIN_CHANGE_INTERRUPT 1 // Enable interrupt functionality
// #define IRMP_ENABLE_RELEASE_DETECTION   1
// #include <irmpSelectMain15Protocols.h>  // This enables 15 main protocols
#define IRMP_SUPPORT_NEC_PROTOCOL 1 // this enables only one protocol
// #include <irsndSelectMain15Protocols.h>
// or use only one protocol to save programming space
#define IRSND_SUPPORT_NEC_PROTOCOL 1
#ifdef ALTERNATIVE_IR_FEEDBACK_LED_PIN
#define IRMP_FEEDBACK_LED_PIN ALTERNATIVE_IR_FEEDBACK_LED_PIN
#endif
#define USE_ONE_TIMER_FOR_IRMP_AND_IRSND 1 // otherwise we get an error on AVR platform:
                                           // redefinition of 'void __vector_8()
 * After setting the definitions we can include the code and compile it.
#include <irmp.hpp>
#include <irsnd.hpp>
IRMP_DATA irmp_data;
IRMP_DATA irsnd_data;
bool bJustReceived = false;
uint8_t _ButtonDebounceCounter = 0;
uint16_t IRMP_KEY = 0;
uint16_t IRMP_LASTKEY = 0;
// uint16_t IRMP_COUNTER = 0;
#define BUTTON_DEBOUNCE_COUNTER_MAX 2;
void handleReceivedIRData();
void setup()
    pinMode(LED_BUILTIN, OUTPUT);
    Serial.begin(115200);
#if defined(__AVR_ATmega32U4__) || defined(SERIAL_USB) || defined(SERIAL_PORT_USBVIRTUAL) || \
    defined(ARDUINO_attiny3217) || defined(ARDUINO_AVR_NANO)
    delay(4000); // To be able to connect Serial monitor after reset or power up and before first print out.
                 // Do not wait for an attached Serial Monitor!
#endif
#if defined(ESP8266) || defined(ESP32)
    Serial.println(); // to separate it from the internal boot output
#endif
  // Just to know which program is running on my Arduino
    Serial.println(F("\r\nSTART " __FILE__ " from " __DATE__ "\r\n\r\nUsing library version " VERSION_IRMP));
    irmp_init();
    irmp_irsnd_LEDFeedback(true); // Enable send signal feedback at LED_BUILTIN
    irmp_register_complete_callback_function(&handleReceivedIRData);
    irsnd_init();
    Serial.print(F("\r\nReady to send / receive IR signals of protocols: "));
    irmp_print_active_protocols(&Serial);
#if defined(ARDUINO_ARCH_STM32)
    Serial.println(F("at pin " IRMP_INPUT_PIN_STRING));
#else
    Serial.println(F("at pin " STR(IRMP_INPUT_PIN)));
#endif
    Serial.println(F("Ready to send IR signals at pin " IRSND_OUTPUT_PIN_STRING)); // the internal pin numbers are crazy for the STM32 Boards library
#else
    Serial.println(F("Ready to send IR signals at pin " STR(IRSND_OUTPUT_PIN)));
#endif
    irmp_irsnd_LEDFeedback(true); // Enable receive signal feedback at ALTERNATIVE_IR_FEEDBACK_LED_PIN
    Serial.println(F("\r\nIR feedback pin is " STR(ALTERNATIVE_IR_FEEDBACK_LED_PIN)));
#endif
    Serial.println(F("\r\n"));
     * Send NEC
    irsnd_data.protocol = IRMP_NEC_PROTOCOL;
    irsnd_data.address = 0xCD27;
    irsnd_data.command = 0x00; // The required inverse of the 8 bit command is added by the send routine.
void loop()
     * Check if new data available and get them
    if (bJustReceived == true)
        if ((irmp_data.protocol == IRMP_NEC_PROTOCOL) && (irmp_data.address == 0xFF80))
            if (irmp_data.flags == 0x00)
                IRMP_KEY = irmp_data.command;
                IRMP_LASTKEY = IRMP_KEY;
                Serial.print(F("IRMP_COUNTER:  "));
                Serial.print(IRMP_COUNTER++);
                Serial.print(F("   "));
                irmp_result_print(&irmp_data);
                if (irmp_data.command == 0x0A)
                    irsnd_data.flags = 1; // repeat frame 1 times
                    irsnd_send_data(&irsnd_data, true);
                    // irsnd_data_print(&Serial, &irsnd_data);
                else
                    // irmp_result_print(&Serial, &irmp_data);
                    Serial.println(irmp_data.command);
                _ButtonDebounceCounter = BUTTON_DEBOUNCE_COUNTER_MAX;
            if ((irmp_data.flags & IRMP_FLAG_REPETITION) && (irmp_data.command == IRMP_LASTKEY))
                if (_ButtonDebounceCounter > 0)
                    _ButtonDebounceCounter--;
                else
                        // irmp_result_print(&Serial, &irsnd_data);
                    else
 * Here we know, that data is available.
 * Since this function is executed in Interrupt handler context, make it short and do not use delay() etc.
 * In order to enable other interrupts you can call sei() (enable interrupt again) after getting data.
void ICACHE_RAM_ATTR handleReceivedIRData()
#elif defined(ESP32)
void IRAM_ATTR handleReceivedIRData()
#else
#endif
    irmp_get_data(&irmp_data);
#if defined(ARDUINO_ARCH_MBED) || defined(ESP32) || defined(ARDUINO_AVR_NANO)
    bJustReceived = true; // Signal new data for main loop, this is the recommended way for handling a callback :-)
#else
    interrupts();                           // enable interrupts
    // irmp_result_print(&Serial, &irmp_data); // this is not allowed in ISR context for any kind of RTOS
#endif
Was passiert?
Es wird gewartet, bis ein IR-Signal empfangen wird, danach ob das Protokoll=NEC ist und die Geräteadresse=0xFF80
Entspricht der Fernbedienung für die Coolstream HD2.
Wenn ja wird noch unterschieden, ob das eine neue Taste ist oder nur deren Wiederholung (Repeat).
Es ist noch etwas "Tasten-Entprellung" eingebaut, ansonsten wird dann nur der Code der Taste über die Serielle Schnittstelle gesendet.
Beispiel:
START src/main.cpp from Jul 1 2023
Using library version 3.6.3
Ready to send / receive IR signals of protocols: NEC, APPLE, ONKYO, at pin 2
Ready to send IR signals at pin 3
IR feedback pin is 6
17/
18
19
20
21
22
für die Tasten 1 bis 6 der Coolstream HD2 Fernbedienung.
Es gibt eine Ausnahme: wenn der Code für die Taste 0x0A ist, wird nur dafür ein IR-Signal auf dann Geräteadresse 0xCD27 gesendet.
Nicht wundern, der gesendete Code ist =0x00 und entspricht der Taste der Fernbedienung zum einschalten für meine Zgemma H7C.
Das ganze jetzt an eine Zgemma H7C per USB-Hub verbunden / angeschlossen.
Bedingung -> /dev/ttyUSB0 entspricht der Verbindung zum Arduino Nano V3.
Die Scripte auf der Box:
iremote_client
#!/bin/bash
echo "iremote_client - start"
INPUT="/tmp/queue.txt"
PIDFILE="/tmp/.jobserver"
if [[ ! -f "$INPUT" ]]; then
    touch "$INPUT"
fi
if [ -e /dev/ttyUSB0 ]; then
	/var/bin/iremote_jobserver &
	/var/bin/iremote_observer &
else
	echo "ERROR: /dev/ttyUSB0 not found"
	echo  "exiting ..."
	exit 1
fi
# stty icrnl -F /dev/ttyUSB0 115200
# sleep 3
stty inlcr -hupcl -F /dev/ttyUSB0 115200
# cat < /dev/ttyUSB0 &
# sleep 1
exec 3>&-
sleep 1
exec 3<> /dev/ttyUSB0
sleep 1
read line <&3
echo $line
read line <&3
echo $line
read line <&3
echo $line
read line <&3
echo $line
while true
do
    read line <&3
#    echo $line
    KEYNAME=""
    # do somthing with it
    if [ $line -eq "31" ]; then
        KEYNAME="KEY_OK"
    elif [ $line -eq "28" ]; then
        KEYNAME="KEY_HOME"
    elif [ $line -eq "0" ]; then
	KEYNAME="KEY_UP"
    elif [ $line -eq "2" ]; then
	KEYNAME="KEY_RIGHT"
    elif [ $line -eq "3" ]; then
	KEYNAME="KEY_LEFT"
    elif [ $line -eq "13" ]; then
	KEYNAME="KEY_MUTE"
	KEYNAME="KEY_RIGHT"
    elif [ $line -eq "1" ]; then
        KEYNAME="KEY_DOWN"
    elif [ $line -eq "7" ]; then
        KEYNAME="KEY_PAGEDOWN"
    elif [ $line -eq "76" ]; then
        KEYNAME="KEY_PAGEUP"
    elif [ $line -eq "4" ]; then
        KEYNAME="KEY_SAT"
    elif [ $line -eq "90" ]; then
        KEYNAME="KEY_NEXT"
    elif [ $line -eq "95" ]; then
        KEYNAME="KEY_PREVIOUS"
    elif [ $line -eq "29" ]; then
        KEYNAME="KEY_RADIO"
    elif [ $line -eq "64" ]; then
        KEYNAME="KEY_MODE"
    elif [ $line -eq "63" ]; then
        KEYNAME="KEY_SUBTITLEST"
    elif [ $line -eq "12" ]; then
        KEYNAME="KEY_GAMES"
    elif [ $line -eq "27" ]; then
        KEYNAME="KEY_FAVORITES"
    elif [ $line -eq "73" ]; then
        KEYNAME="KEY_AUDIO"
    elif [ $line -eq "15" ]; then
        KEYNAME="KEY_HELP"
    elif [ $line -eq "62" ]; then
        KEYNAME="KEY_LAST"
    elif [ $line -eq "30" ]; then
        KEYNAME="KEY_EPG"
    elif [ $line -eq "11" ]; then
        KEYNAME="KEY_INFO"
    elif [ $line -eq "14" ]; then
        KEYNAME="KEY_VOLUMEUP"
    elif [ $line -eq "72" ]; then
        KEYNAME="KEY_VOLUMEDOWN"
    elif [ $line -eq "89" ]; then
        KEYNAME="KEY_RECORD"
    elif [ $line -eq "68" ]; then
        KEYNAME="KEY_REWIND"
    elif [ $line -eq "69" ]; then
        KEYNAME="KEY_FORWARD"
    elif [ $line -eq "47" ]; then
        KEYNAME="KEY_WWW"
    elif [ $line -eq "70" ]; then
        KEYNAME="KEY_PLAYPAUSE"
    elif [ $line -eq "65" ]; then
    elif [ $line -eq "71" ]; then
        KEYNAME="KEY_STOP"
    elif [ $line -eq "5" ]; then
        KEYNAME="KEY_RED"
    elif [ $line -eq "9" ]; then
        KEYNAME="KEY_GREEN"
    elif [ $line -eq "66" ]; then
        KEYNAME="KEY_YELLOW"
    elif [ $line -eq "67" ]; then
        KEYNAME="KEY_BLUE"
    elif [ $line -eq "16" ]; then
        KEYNAME="KEY_0"
    elif [ $line -eq "17" ]; then
        KEYNAME="KEY_1"
    elif [ $line -eq "18" ]; then
        KEYNAME="KEY_2"
    elif [ $line -eq "19" ]; then
        KEYNAME="KEY_3"
    elif [ $line -eq "20" ]; then
        KEYNAME="KEY_4"
    elif [ $line -eq "21" ]; then
        KEYNAME="KEY_5"
    elif [ $line -eq "22" ]; then
        KEYNAME="KEY_6"
    elif [ $line -eq "23" ]; then
        KEYNAME="KEY_7"
    elif [ $line -eq "24" ]; then
        KEYNAME="KEY_8"
    elif [ $line -eq "25" ]; then
        KEYNAME="KEY_9"
    elif [ $line -eq "46" ]; then
        KEYNAME="KEY_SLEEP"
    elif [ $line -eq "60" ]; then
        KEYNAME="KEY_MOVE"
    elif [ $line -eq "94" ]; then
        KEYNAME="KEY_TIME"
    elif [ $line -eq "26" ]; then
        KEYNAME="KEY_MENU"
    fi
    if [[ -n $KEYNAME ]]; then
#	echo $KEYNAME
#	/usr/bin/wget -O /dev/null -q "http://localhost/control/rcem?$KEYNAME"
        /var/bin/queue.sh offer "$KEYNAME"
        if [[ ! -f "$PIDFILE" ]]; then
            else
	        echo  "exiting ..."
	        exit 1
            fi
        fi
    else
	echo "unknown KEYNAME"
    fi
done
exec 3<&-
iremote_jobserver
#!/bin/bash
OUTPUT="/tmp/trash.txt"
    touch "$PIDFILE"
fi
CNT="0"
while true
do
    if [[ -f "$INPUT" ]]; then
        COUNTER=0
        COUNTER="$(stat -c %s "$INPUT")"
        # if [ -s "$INPUT" ]; then
        if [ "$COUNTER" -gt 0 ]; then
            # echo "polling ..."
            /var/bin/queue.sh poll
            CNT="0"
        else
            # echo "sleeping ..."
            CNT=$((CNT + 1))
            if [[ "$CNT" -gt "100" ]]; then
                break
            fi
            usleep 50000
            # sleep 1
        fi
    else
        # echo "$INPUT" "not exist"
        sleep 1
    fi
    # COUNTER=$(wc -l "$INPUT" | cut -d " " -f 1)
    # if [ $COUNTER -gt 0 ]; then
    #	/var/bin/queue.sh poll
    # else
    #	usleep 10000
    # fi
done
if [[ -f "$PIDFILE" ]]; then
    rm -f "$PIDFILE"
fi
exit 0
iremote_observer
#!/bin/bash
while true
do
	sleep 60
    else
	killall iremote_client
	reboot
    fi
done
queue.sh
#!/bin/bash
# This script encapsulates the functionality of a queue. It requires there to be
# an input file with the data in the queue being separated on different lines.
INPUT=/tmp/queue.txt
OUTPUT=/tmp/trash.txt
CMD=/usr/bin/wget
if [ ! -f "$INPUT" ] ; then
    touch "$INPUT"
fi
wait_rcsim_done() {
    COUNTER=0
    # /bin/usleep 10000
    while [ $(ps acux | grep -c '[/]usr/bin/wget -t 2 --no-cache -O /dev/null -q') -gt 0 ]; do
	COUNTER=$((COUNTER + 1))
	/bin/usleep 10000
	if [ $COUNTER -gt 200 ]; then
	    killall wget
	    break
	fi
	# echo $COUNTER >> /tmp/wait_rcsim.txt
    done
# poll() removes the top line from $INPUT and appends it to the $OUTPUT file
poll() {
    if [ ! -f "$CMD" ] ; then
	echo "$CMD does not exist" 1>&2
	exit 1
    fi
    if [ ! -x "$CMD" ] ; then
	echo "$CMD is not executable" 1>&2
	exit 1
    fi
    head -1 "$INPUT" >> "$OUTPUT" && sed -i '1d' "$INPUT"
    ENTRY="`tail -1 "$OUTPUT"`"
#    $("$CMD" "$ENTRY")
    if [[ -n $ENTRY ]]; then
	if [[ $ENTRY == "KEY_TIME" ]]; then
	    /usr/bin/rcsim $ENTRY > /dev/null 2>&1
	else
	    # /usr/bin/wget -t 2 --no-cache -O /dev/null -q "http://127.0.0.1/control/rcem?$ENTRY" &
	    # wait_rcsim_done
	    /bin/usleep 100000
	fi
	sed -i '1d' "$OUTPUT"
    fi
# offer() appends the given arguments to the $INPUT file
offer() {
    for arg in ${@:2} ; do
	if [ -n "$arg" ] ; then
#	    echo "$arg"
	    echo "$arg" >> "$INPUT"
	fi
    done
# peek() prints the next entry in the queue
peek() {
    head -1 "$INPUT"
# random() passes a random line from $INPUT to $CMD
random() {
	exit 1
    fi
	exit 1
    fi
    COUNT=`cat "$INPUT" | wc -l`
    if [ "$COUNT" -lt 1 ] ; then
	exit 0
    fi
    RANDOM_LINE_NO=$[ ( $RANDOM % $COUNT ) + 1 ]
    RANDOM_LINE=`sed -n ''"$RANDOM_LINE_NO"'p' "$INPUT"`
    $("$CMD" "$RANDOM_LINE")
print_help() {
    cat << EOF
USAGE:
  queue COMMAND
COMMANDS:
  poll
    removes the top line from \$INPUT and appends it to the \$OUTPUT file
  offer
    appends the given arguments to the \$INPUT file
  peek
  random
    passes a random line from \$INPUT to \$CMD
EXAMPLES:
  To offer a list of files to the queue:
    find /path/to/files | xargs ./queue.sh offer
EOF
if [ "$1" == "poll" ]
then
    poll
elif [ "$1" == "offer" ]
then
    offer $*
elif [ "$1" == "peek" ]
then
    peek
elif [ "$1" == "random" ]
then
    random
else
    print_help
    exit 1
fi
Der Observer ist nicht wirklich notwendig, bei mir verschwindet nur der Arduino manchmal und taucht dann unter /dev/ttyUSB1 wieder auf.
Muss ich mal noch genau klären, was die Ursache ist (Kernel-Treiber / USB-Spannung).
Die Scripte befinden sich bei mir derzeit unter /var/bin/ , können sich aber auch wo anders befinden.
Bei Bootvorgang muss iremote_client mit gestartet werden. Ich habe das mit der /etc/rc.local erledigt.
#!/bin/sh -e
# /etc/rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
/var/bin/iremote_client &
exit 0
Was bezwecke ich jetzt damit. Ich warte, das vom Arduino Nano V3 eine Textmeldung kommt, vergleiche sie mit einer Soll-Liste und
lege ein selbst gewünschtes Neutrino-KEYNAMES-Mapping fest. Das wandert in einer Arbeitsqueue, welche dann abgearbeitet wird.
Damit gewährleiste ich, das jedes Signal vom Arduino auch empfangen wird und dann asynchron verarbeitet werden kann.
Es kann z.B. wunderbar durch lange Filmlisten gescrollt werden.
Hoffentlich habe ich nichts vergessen. Bei Unklarheiten kann gerne nachgefragt werden.
Has thanked: 22 times
Re: Benutzung von alternativen Fernbedienungen
vielen Dank, dass du dein Projekt hier vorstellst. :thumbsup:
Die folgenden Fragen bitte nicht als Kritik verstehen, sondern als ehrliches Interesse. Auch, wenn ich das so wie ich es zZt verstehe vermutlich garnicht nutzen könnte.
Mich würde deine fertige Lösung interessieren, also ein Bild davon, ich kann mir das iwie noch nicht ganz vorstellen, wie es aussieht. Dein Nano wird ja iwo zw dir bzw der FB und dem Receiver platziert sein?
Ist das Ding per USB an der Box angeschlossen, die du mit der Fremd-FB bedienen willst? Oder per ext USB-Netzteil (wegen Deep-Standby)?
Und für die folgende Frage habe ich Gorcons Wunsch im Hinterkopf , die ungenutzten aber möglichen FB-Codes für Automatisierungszwecke verfügbar zu machen: da ja anscheinend der Original-"FB-Treiber" diese ungenutzen Codes nicht "weiterleitet", wäre das dann evtl durch diese Lösung hier möglich???
edit und PS:
seife hat geschrieben: ↑Mo 3. Jul 2023, 08:37 ich würde trotzdem gleich einen Leonardo klon holen, denn dann hält man sich die Option einer Tastaturemulation offen
wie sähe das dann aus, bzw was wäre damit möglich???
seife
Has thanked: 3 times
Been thanked: 14 times
Beitrag von seife »
Don de Deckelwech hat geschrieben: ↑Sa 8. Jul 2023, 21:14 edit und PS:
Der Leonardo, mit ATMega32u4, kann direkt eine USB-Tastatur emulieren.
Damit könnte man dann direkt als Input-device im Linux ankommen und wenn man dem Ding noch eine eindeutige USB-ID mitgibt, dann könnte man das sogar direkt im Neutrino einbauen daß das diese "Tastatur" ohne Änderungen / Konfiguration unterstützt.
MCP's Variante ist, daß er die IR-Keycodes per Serieller Schnittstelle an die Box schickt, wo dann ein skript läuft was diese Codes auswertet und per rcsim die Tastendrücke simuliert.
[MCP]
Beitrag von [MCP] »
Don de Deckelwech hat geschrieben: ↑Sa 8. Jul 2023, 21:14 Hi,
edit und PS:
und Danke für das Interesse.
Die von mir gewählte Stromversorgung für den Arduino Nano V3 habe ich erst einmal unterschlagen.
Normal wird der Nano V3 per passenden USB-Kabel direkt mit der Kabel / Sat Box verbunden.
Also Box USB-A - Nano USB-B (mini oder micro).
Damit liefert der Linuxkernel per CH340 Treiber ein Serielles Device auf der Box und
man kann mit passenden Parametern darauf zugreifen z.B. 115200 8-N-1
Die Stromversorgung für den Nano V3 kommt dann dabei von der Box (5 Volt per USB).
Wenn die Box aber aus ist, sind auch die 5 Volt weg. Also Arduino auch aus.
Um das zu umgehen, benutze ich noch extra einen aktiven USB-Hub der sich zwischen Box
und Arduino befindet. Die 5 Volt Spannung für den USB- Hub wiederum gewinne ich aus den 12 Volt
des Netzteils für meine Box. Dort habe ich ganz simpel einen Splitter verwendet, der dann 2x
12 Volt liefert. Einmal geht weiter zur Box. Aus den zweiten 12 Volt wird per Step-Down Wandler
5V bereitgestellt (z.B. per LM2596S) -> USB-Hub hat Spannung, auch wenn Box aus,
damit ist der Arduino weiter aktiv mit Spannung versorgt und kann seine Arbeit verrichten.
Die weitere Verarbeitung der Daten vom Arduino mit Scripten habe ich deshalb gewählt,
damit ich jederzeit schnell Änderungen und Ideen umsetzen kann.
Der Kreativität sind keine Grenzen gesetzt. Das wirklich wichtige für die jetzige Variante
sehe ich darin, das jeder selbst seine Wünsche realisieren kann.
Die eigene Tastenzuordnung ist doch nur eine Möglichkeit.
Es lassen sich eben bisher ungenutze Tasten der Fernbedienung für andere Dinge verwenden.
Die Verwendung der Control-API von nhttpd lässt alles zur weiteren Benutzung zu.
Ich denke z.B. daran, mit einer Fernbedienungs Taste ganze Plugins auszuführen zu können
oder eigene Abläufe zu erfinden. Dazu muss man aber Neutrino nicht anfassen oder
was ganz neues programmieren. Es reichen einfache Shell Befehle dafür und dies ist aus meiner Sicht
einfacher erlernbar, wenn man sich darin ausprobieren möchte.
Tastatur-Emulation per Arduino habe ich selber einfach noch nie benutzt,
deshalb auch absolut keine Erfahrung dazu.
Den wirklichen Mehrwert darin sehe ich derzeit nicht.
Man entschuldige menen vielleicht begrenzten Horizont, aber ich sehe eher mehr Komplexität,
um doch nichts anderes zu erreichen.
Das kann aber jeder trotzdem selbst festlegen und seinen Weg wählen.
PS:
Genau das ist eben damit endlich machbar:
KEY_POWERON nebst KEY_POWEROFF auch für Fernbedienungen, die das bisher nicht trennen können.
Zurück zu „Hardware“
