NI-Image 3.2 (Changelog) - Rolling Release
Gesperrt
Has thanked: 64 times
Been thanked: 106 times
:N:eue :I:mages für alle Boxen online.
Image:
- Neues Benutzer-Bouquets Plugin im Image (Menü -> Service -> Benutzer-Bouquets)
- pr-auto-timer v0.38a
Neutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... d03b6ce89a)
- cc_detailsline: use a smaller thickness
- volumebar: don't use frame around volumebar
- imageinfo_ni: remove unused code around astrasat logo
- imageinfo_ni: remove remote-commit info
Re: NI-Image 3.2 (Changelog) - Rolling Release
Jede Menge aktualisierte Tools und Libs im Image!
Image:
- shellexec v1.30; smoother fontrendering
- bash: bump version to 4.4; remove 4.3-patches
- .version: rename entry "origin-commit" to "commit" to match imageinfo_ni
- flex_plugins.conf: small cosmetic change
- freetype: add patch to enable TT_CONFIG_OPTION_SUBPIXEL_HINTING ...
- libbluray: fix patch
- libbluray: bump version to 0.9.2
- userbouquets.lua: v0.11; fix data_dir
- zic: bump version to 2016f
- libgcrypt: bump version to 1.73
- libupnp: bump version to 1.6.20
- libaacs: bump to version 0.8.1
- libaacs/KEYDB.cfg: upgrade
- busybox: bump version to 1.25.0
- fix tuxwetter build against giflib 5.1.4
- giflib: bump version to 5.1.4 again
- dropbear: bump version to 2016.74; align and cleanup patches
- dosfstools: bump version to 4.0; align target
- wget: bump version to 1.18; align patches
- freetype: bump version to 2.6.5
- libcurl: bump version to 7.50.0
- libpng: bump version to 1.6.25
Neutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... i/cst-next)
- neutrino: remove ng leftovers
- lcd4l: try to fix encoding mess again
- imageinfo_ni: Fix memory error
- imageinfo_ni: fix generic build
Image:
- rssreader.conf: remove feed to CST-git
- openssl: bump version to 1.0.2j
- busybox: bump to version 1.25.1
- switch to new ni/tuxbox branch; ni/cst-next was removed
- switch to tuxbox-neutrino repositories
- pr-auto-timer: v0.38b
- flex-menu: add lotto plugin
Neutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... =ni/tuxbox)
- audioplayer: fix topbox colors; ... we're using header colors as in upnpbrowser too
- Recording Menu: Add option "Always show timer pick list" - "when choosing recording from EPG, view Timer list even no further entries found" yes/no
- timerlist: change colors for remote-timer (as requested by tewsbo)
- imageinfo_ni: align fade code to other fade code
- imageinfo_ni: allow fade in/out
Neu sind auch die Umgestaltungen am Moviebrowser. Die habe ich von Tuxbox-Neutrino einfach mal mit übernommen, um sie euch auf's Auge zudrücken. ;) Schaut mal, ob da alles soweit passt.
Der Bug mit den nacheinander folgenden Timern besteht nach wie vor. Stellt also bitte genügend Nachlaufzeit für die Aufnahmen ein. Dann tritt der Fehler, dass Aufnahmen fehlen, nicht auf. Es wird daran gearbeitet.
Image:
- fix builddate
- webtv: update filmon.lua
Neutrino:
- acinclude.m4: fix WEBTVDIR
- timerlist: try to fix segfault in askUserOnTimerConflict()
- deutsch.locale: minor changes in menu.hint_record_tevents
:I:mage:
- fix builddate (This time for real. ;))
- webtv: update filmon.lua (auto-EPG)
- libcurl: bump version to 7.51.0
- openvpn: bump version to 2.3.12
- hdparm: bump version to 9.50
:N:eutrino:
- osd_setup: change moviebrowser's default font sizes
- moviebrowser: use own defaults for moviebrowser's view
- record.cpp: avoid segfault in CRecordManager::getUseCI()
- lcd4l: try to fix ModeCam detection
- lcd4l: new features
* Resolution detection (/tmp/lcd/resolution)
* AspectRatio detection (/tmp/lcd/aspectratio)
* Videotext detection (/tmp/lcd/videotext; "yes", "no")
* DolbyDigital detection (/tmp/lcd/dolbydigital; "yes", "available", "no")
- lcd4l: reduce console spam in module detection
- timerlist: reduce flicker-effects while timerlist construction
- eventlist: show left/right buttons in footer
- webtv: try to auto-add epg from existing channels (experimental)
Die Probleme bei den Wiederholungstimern wurden gefixt.
Die Möglichkeit, die Folgeevents bei der Timerprogrammierung einzustellen, ist ins Timermenü gewandert. (Menü -> Einstellungen -> Aufnahme -> Timer)
Im Moviebrowser hab ich die Schriftgröße und die Spaltenaufteilung geändert. Wer alles so lässt, wie es ist, wird nichts davon merken, da eure Einstellungen ja erhalten bleiben.
Setzt man allerdings im OSD-Setup die Schriftarten für den Moviebrowser auf die Voreinstellungen und stellt im Moviebrowser die Ansicht auf die Voreinstellungen, bekommt man die geänderte Ansicht.
Beim WebTV ist eine auto-EPG-Funktion neu. Trägt man ins xml epgid="auto" ein, wird nach einem passenden Sender in den Kanallisten gesucht. Wird einer gefunden, wird dessen EPG für den WebTV-Kanal benutzt. Dieses Feature ist noch experimentell. Unsere FilmON-Liste ist damit bereits ausgestattet.
Die FilmOn-Liste ist auch auf dem aktuellen Stand. Es wurden alle Sender von FilmON automatisch ausgelesen und ins xml eingetragen.
Viel Spaß mit den Images. ;)
:N:eue :I:mage-Updates für alle Boxen online.
Grundlage für dieses Update ist das letzte Rolling Release vom Donnerstag, dem 17.11.2016. Ob das Update auch in älteren Images läuft, kann ich nicht versprechen.
:N:eutrino:
- re-add our welcome message to vfd; we're NI \o/
dbt hat die Messageboxen komplett überarbeitet.
Das automatische Anpassen eurer Timer an das EPG wurde deaktiviert. Somit sind die Probleme damit nun vom Tisch. Dass Timeraufnahme nicht funktionieren, ist ein No-Go. Bei unseren Tests war das keinem aufgefallen. Das scheint nur unter gewissen Umständen zugeschlagen zu haben.
Viel Spaß mit den Updates.
:N:eutrino:
- locale: re-add the name "Neutrino" instead of "GUI" in some locales
- osd_setup: use proven font styles (bold, w/o offset) for msgboxes
- settings_manager_teams: simplify hintbox calls
- ni_menu: simplify and fix hintbox calls
- netfs_setup: simplify hintbox calls
- lcd4l_setup: remove obsolete hintbox include
- eventlist: fix button_label size
Es hatten sich noch paar Ungereimtheiten bei den neuen Messageboxen eingeschlichen, die nun ausgemerzt wurden.
Gesperrt
