NI-Image 3.2 (Kronos v2) - Rolling Release
Has thanked: 64 times
Been thanked: 107 times
Viel Spaß mit dem Image. ;)
:NI: \o/
jaro44
Box: tank, trinity duo, xsarius alpha hd
Re: NI-Image 3.2 (Kronos v2) - Rolling Release
Beitrag von jaro44 »
Each time they I enter the settings for the remote control suspend box,
var partition cleaned and the problem remains :(
I don't understand. Can you explain?
Or log your steps. Then we'll see, what you mean.
jaro44
whenever I go to menu-->settings-->remote control my trinity duo suspended, on original FW all is ok
Has thanked: 16 times
Been thanked: 12 times
You want to change the Remote Control?
Edit: I tested just now on my Neo2. Philips works not, d-Box old ist working. I have no triple Dragon remote control
jaro44
I don't want to change the Remote Control, I want change settings remote control in menu-->settings-->remote control.
But I can not, because then my Trinity Duo suspended (crash, only hard reset it revives)
jaro44 hat geschrieben:I don't want to change the Remote Control, I want change settings remote control in menu-->settings-->remote control.
There is no spezial remote control setting in our menu.
Do you made a factory resett after you flashed our image?
Has thanked: 88 times
Been thanked: 59 times
he said yes.
but there is no setting in NI about remote control. I changed the language to english.
@ jaro
please go to this menu,
factory reset and reboot.
greetz Knicko
jaro44
and key setup what is it? Is not setting the remote control?
but I did it, the problem caused file polski.locale, i back to english and all work ok.
Thx, problem is solved, I just have to fix my file polski.locale.
