Tipard Video Enhancer 9.2.52 & Plague and Steel
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Tipard Video Enhancer 9.2.52
Tipard Video Enhancer is the enhancing tool which can improve video quality in color balance and resolution even video de-shaking. With the enhancing features, you can even convert your files to 1080p HD or 4K video. It can also edit videos, including rotating, cropping, 3D, watermark, and trimming. Besides, it can convert video formats. Almost all popular formats are supported. You can convert your video files to MP4, MOV, AVI, MKV, WMV, and more. In addition, you can extract the audio from video files. Accordingly, you can save them as many formats, including AAC, MP3, WAV and so on.
Key functions and features:
1. Enhance video quality by upscaling resolution, removing video noise, and reducing video shaking.
2. Trim video to remove unwanted parts and merge the trimmed segments.
3. Add editing features, such as effect and watermarks.
4. Adjust audio track and subtitles and rename the added files.
5. Merge the input files into one and adjust the order.
6. Preview the output video to adjust settings in time.
Tipard provides 35% off discount of Video Enhancer for all GOTD users.
Link
Game Giveaway of the day — Plague and Steel
"Plague and Steel" is an exciting top-down third-person shooter, which takes place in the labyrinths of a military laboratory where zombies were cloned. However, something went wrong, and now you have to clean up the entire base from this evil.
In the game you will face not only zombies, but also armed soldiers who will guard the base. You will have to use all your skills and tactics to destroy all life on the base and find a way out.
The goal of the game is to go through the maze, destroying zombies and soldiers, and find a way out. You will also have to look for first aid kits and cartridges that will help you move on.
The game consists of one large maze that you have to explore to find a way out. You have to be careful and tactful not to fall into traps and not die from enemy attacks.
Controls: Mouse and WASD The "F" button turns on a little lighting around
Link
mfG
Trapped
Kein Support per PN/Mail
