Tabbles for Small Groups 4.0.10
Keine Stimmen
trapped
Beitrag von trapped »
Giveaway of the day — Tabbles for Small Groups 4.0.10
Using Tabbles you can categorize your files, folders or internet addresses by cross-linking them to one or more tabbles. A tabble is a visual tag that behaves like a virtual folder.
Since Tabbles is a desktop application, it's well integrated into the Microsoft Windows environment: categorization can be done using the usual explorer functions, such as copy-and-paste, drag-and-drop (keyboard shortcuts and right-button menu included) or using the buttons on the tabble's.
Please note: Tabbles for Small Groups is a special build developed specificaly for Giveaway of the Day users and it slightly differs from the Home version:
Visual Tagging: Unlimited
Explorer Integration: +
Outlook Integration: +
Access your tagging from several PCs: -
Cloud Synchronization tagging: - (“LocalDB” and the “LAN” mode)
Tag sharing: Up to 3 users (one user per license)
Comparison with other versions is available here
Link
mfG
Trapped
Kein Support per PN/Mail
