Tipard Screen Capture 2.1.18 & Product Key Recovery Tool 2.0.1 & Falco Dog
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Tipard Screen Capture 2.1.18
Tipard Screen Capture is a professional recording tool that can help you capture screen activities and videos/audio on PC/Mac. It is your best choice to create some tutorials, take screenshots, record webcam, capture video call chats, make game videos, and record iOS and Android phone screen on your computer.
Key functions and features:
1. Customize the recording area according to your needs.
2. Record video/audio files and save them with the original quality.
3. Add real-time drawing tools, such as arrows, text, shapes, and lines.
4. Preview and trim the captured video immediately after you finish recording.
5. Set task recording so you can record the screen without sitting in front of the computer.
6. Take screenshots and save them in popular image formats, like JPG, PNG and GIF.
Tipard provides 35% off for all GOTD users.
Link
Giveaway of the day — Product Key Recovery Tool 2.0.1
Es kommt oft vor, dass ihr euren Computer aus irgendeinem Grund neu einrichten und alles re-installieren müsst, könnt dabei eure Produktinstallationsschlüssel nicht in eurer bevorzugten oder kostenpflichtigen Software und Spielen finden. Das Product Key Recovery Tool ist hier, um euch bei diesem Problem zu helfen. Dieses Tool kann die meisten Schlüssel eurer bereits installierten Lieblingsprogramme und -spiele finden und wiederherstellen und bietet einige andere Vorteile. Das Programm kann auch Installationsschlüssel von externen nicht bootfähigen oder beschädigten Festplatten wiederherstellen.
You can purchase a special Lifetime license (with support and updates) with 50% discount using coupon code "GOTD50" on order page!
Link
Game Giveaway of the day — Falco Dog
The dog was attacked by killer bees and only you can save her! Draw lines through which the bees will not be able to break through and bite the dog, because only you can save her!
Sometimes you have to be smart to achieve success. Can you complete all levels of the Falco Dog game?
Link
mfG
Trapped
Kein Support per PN/Mail
