Shadow Defender 1.4 & Iris Mini Pro 0.1.6 Portable (Win & Mac)
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Shadow Defender 1.4
What is Shadow Defender?
Shadow Defender is an easy, powerful and effective security solution that protects your PC/laptop against malicious activities and unwanted changes.
Shadow Defender can run your system in a virtual environment called 'Shadow Mode'. 'Shadow Mode' redirects each system change to a virtual environment with no change to your real environment. If you experience malicious activities and/or unwanted changes, perform a reboot to restore your system back to its original state, as if nothing happened.
With Shadow Defender, you have the flexibility to specify which files and folders are permanently saved to the real environment. This ensures important files and folders are kept after a reboot.
If you want to make a maintenance-free computer, Shadow Defender will be your best choice.
Shadow Defender Features
Prevent all viruses and malwares.
Surf the internet safely and eliminate unwanted traces.
Protect your privacy.
Eliminate system downtime and maintenance costs.
Reboot to restore your system back to its original state.
Shadow Defender Users
Maintain a system free from malicious activities and unwanted changes.
Test software and game installations in a safe environment.
Protect against unwanted changes by shared users (suitable for workplaces and educational institutions).
Link
Giveaway of the day — Iris Mini Pro 0.1.6 Portable (Win & Mac)
Iris Mini ist eine Augenschutz-Software, welche die Farbtemperatur auf eurem Bildschirm sowie seine Helligkeit reduziert ohne die Flimmerrate zu erhöhen.
Nachts unterdrückt blaues Licht die Produktion von Melatonin, dem Schlafhormon. Abhängig von eurer Location passt Iris die Bildschirmfarbe an und fügt etwas mehr rot oder gelb hinzu - ähnlich wie f.lux, Night Shift und weitere Blaulicht-Blockiertools.
Eine andere coole Funktion ist die Anpassung der Helligkeit. Wenn der Bildschirm die ganze Zeit flimmert, registriert unser Auge das kaum. Da es nicht möglich ist, einen flimmerfreien Bildschirm herzustellen, lösen wir dieses Problem auf eine andere Weise. Die meisten Bildschirmhersteller kontrollieren die Helligkeit, indem sie die Flimmerrate reduzieren (die sogenannte Pulsweitenmodulation). Je niedriger diese Frequenz, desto mehr leiden unsere Augen darunter! Darauf folgen Kopfschmerzen, Augenprobleme, Schlafstörungen usw. Die Lösung lautet Iris Mini, denn dieses Tool ändert die Helligkeit ohne die Flimmerrate zu reduzieren.
GOTD und ich hoffen, dass ihr dieses wunderbare kleine Tool nützlich findet!
Daniel Georgiev, der Iris-Gründer.
Bitte beachtet: MAC-Benutzer können Iris Mini hier herunterladen.
Link
mfG
Trapped
Kein Support per PN/Mail
