Coolmuster Data Recovery 2.1.23 & Forgotten Collections 2
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Coolmuster Data Recovery 2.1.23
Für viele Menschen kann Datenverlust eine große Katastrophe bedeuten, besonders wenn ihre Dateien nicht regelmäßig gesichert werden. Coolmuster Data Recovery hilft euch, ein sorgenfreies digitales Leben zu führen!
Features:
Wiederherstellen von über 550 Formaten inklusive Fotos, Videos, Musik, Dokumente, Emails, .zip, usw.
Wiederherstellen von gelöschten, formatierten oder nur teilweise verfügbaren Dateien.
Retten von Daten auf internen und externen Datenträgern.
Link
Game Giveaway of the day — Forgotten Collections 2
In the second part of the Forgotten Collections game, you will have to complete 16 levels, each of which is a puzzle of 45 elements. Your goal is to collect all the pieces to reveal the image of a unique object and move on to the next level.
You can select any level from the list and start building. Before starting each level, you will be shown the original image of the item, which will help you understand how the assembled image should look. If you need a hint, just click on the button with the question mark.
If the level turns out to be too difficult, don't worry! You can click on the arrow to move to the next level, even if the current one is not completed yet.
When all the details are correctly assembled, a message will appear about the completion of the level, and the game will move on to the next stage, revealing new secrets of unique objects to you.
At each level, the first element of the picture, marked with an asterisk, is located in the upper left corner, which makes the task easier.
Link
mfG
Trapped
Kein Support per PN/Mail
