HEIC to JPG Converter 13.2 & Apeaksoft Blu-ray Player 1.1.52 & WB Wizard
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — HEIC to JPG Converter 13.2
HEIC to JPG converter easily converts .heic or .heif photos from your iPhone or iPad into any popular graphic format (JPG, PNG, it also supports RAW images (CRW, CR2, NEF, PEF, RAF, RAW, DNG, MNG, etc) High Efficiency Image File Format (HEIC) is used by default on new photos on iOS 10 - 12, and it's there to save your storage space. It's new so it has to face some incompatibilities. HEIC format is still not supported by the popular graphic editors and viewers and Apple hasn't offered a solution yet. HEIC to JPG converter not only converts .heic photos from your iOS device to other formats but also introduces a simple drag&drop user interface and delivers fast and smooth image conversion. It can help you quickly finish batch image resizing for sharing and publishing your photos. Optionally, you can add text, logos and image watermarks to protect the converted pictures, as well as change canvas size, flip images, mirror, rotate them in the process, plus adjust level and color. For more advanced users GUI and command line are available. The files can also be renamed in batch mode. The program smoothly integrates with Windows 7, 8 and 10 Explorer.
Purchase an Unlimited personal license (with support and updates) at 70% discount!
Link
Giveaway of the day — Apeaksoft Blu-ray Player 1.1.52
Apeaksoft Blu-ray Player gives you an immersive visual experience when playing Blu-ray/DVD discs, folders or ISO files on your computer. Also, it helps you play 4K videos in MP4, WMV, ASF, MKV, FLV, VOB, AVI and more formats smoothly. With the latest Blu-ray technology, you can enjoy and customize your Blu-ray playback with various settings. It also supports DTS-HD Master Audio, Dolby TrueHD, and Apple Lossless Audio Codec, which brings you lossless audio and dramatic HD surround sound effects.
There is a special offer for GOTD users to get Apeaksoft Blu-ray Player (Lifetime License) with 40% off.
Link
Game Giveaway of the day — WB Wizard
WBWizard is a game in which you and your friends take on the role of powerful wizards who fight each other in magical arenas. Use a variety of spells to defeat your opponents and be the last surviving wizard in the arena.
Link
mfG
Trapped
Kein Support per PN/Mail
