SoftOrbits AI Photo Editor 10 & Hybridosaurs
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — SoftOrbits AI Photo Editor 10
Tired of spending hours editing your photos? With AI Photo Editor, you can get professional-looking results in minutes. Our AI-powered features make it easy to enhance your photos with just a few clicks.
If you have a GPU with more than 4 GB of memory, you can also use the AI functions of the SoftOrbits AI Photo Editor. These functions include:
Key Features:
• Smart Portrait Enhancement: Our AI technology automatically detects and enhances your facial features, giving you a flawless, natural-looking portrait.
• Smart Background Manipulation: Easily remove unwanted objects from your photos or replace them with a new background.
• Intelligent Object Removal & Addition: Our AI can intelligently remove objects from your photos or add new ones, seamlessly blending them into your image.
• High-resolution support: Edit and save your photos in ultra-high resolution for the best possible quality.
• Customizable prompts: Customizable prompts to get the exact results you want.
• Non-destructive editing: Edit your photos without damaging the original files.
• Customizable AI preferences: Adjust the strength of AI effects to get the perfect look for your photos.
Purchase an Unlimited personal license (with support and updates) at 70% discount!
Link
Game Giveaway of the day — Hybridosaurs
The Hybridosaurs game consists of 16 levels, each of which is a 45-element puzzle. The theme of the game is unusual dinosaurs that vaguely resemble modern animals. Your goal is to collect all the pieces of the puzzle to see the full picture and move on to the next level. You can select any level from the list and start building. Before starting each level, you will see the original image of the picture, which will help you understand what the assembled puzzle should look like. If you need help, just click on the question mark button. If the level seems too difficult to you, don't worry! You can click on the arrow to go to the next level, even if the current one has not been completed yet. When all the pieces are assembled correctly, a message will appear indicating the completion of the level, and the game will move on to the next level. At each level, the first element of the drawing, marked with an asterisk, is located in the upper-left corner, which makes the task easier.
Link
mfG
Trapped
Kein Support per PN/Mail
