Jet Screenshot Home 3.1 & Falco Jumper
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Jet Screenshot Home 3.1
Jet Screenshot is a screen capture service enabling you to share screenshots online in seconds. Take a screenshot, edit and send it to the web, and immediately provide anyone with a link to the image. It is a perfect solution for specialists working remotely: programmers, designers, QA testers, bloggers, technical assistance specialists, sales managers etc.
Jet Screenshot helps make online communication easier by using images and it does it in a quick and convenient manner. You press PrintScr and select the screen area that you want to show to the other party. Add visual markers and click "Share in Web". Jet Screenshot turns the image into a URL that is automatically copied to the clipboard. All you need to do now is to press Ctrl+V to send the URL to the person you are chatting or exchanging emails with. Jet Screenshot does not require any third-party tools on either end of the line. The other person just has to click the link you sent them.
Link
Game Giveaway of the day — Falco Jumper
In Falco Jumper, you control a bouncy yellow and black ball that bounces along wooden platforms floating high in the sky. Each touch of a platform gives you a new push upward, and your task is to get as high as possible while avoiding the chasms.
Link
mfG
Trapped
Kein Support per PN/Mail
