MobiKin Assistant for Android 4.2.46 & File Sharing Pro 3.4.4.40 & Falco 25 Train Reaction
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — MobiKin Assistant for Android 4.2.46
Looking for a simple way to manage your Android device? Then this MobiKin Assistant for Android could be the ideal solution for you. Just get it to learn its powerful management ability now.
Link
Giveaway of the day — File Sharing Pro 3.4.4.40
File Sharing Pro is a secure file sharing software that uses native operating system file sharing security and a professional web server for you to securely share your files using any web browser on any device.
File Sharing Pro file sharing app only requirement is for you to setup a port forward on your router. After that you're ready to share documents, photos, videos, and music securely over the Internet with your contacts.
File Sharing Pro windows file server and mac file server publishes a secure web site users can connect to using any device and any web browser. After successfully logged in users can browse and download images, videos, music, and documents, plus users can upload files.
File Sharing Pro supports large file sizes both for download and upload. With File Sharing Pro, there are no third parties involved and no privacy concerns. If you like to keep sensitive files private File Sharing Pro is your budget friendly file sharing software solution.
Main Features:
1. Professional web server that works with operating system security authentication to publish and protect your files.
2. Easy to use user interface.
3. Web server support for 100+ over mime types.
4. Support for large files.
5. Support for client file uploading.
Extra Features:
1. Ability to assign the pages a user is allowed to visit.
2. Ability to share executable files.
If you're looking to share files over the Internet with full security through a regular browser, then File Sharing Pro is certainly the best option you have specially at this price range.
Link
Game Giveaway of the day — Falco 25 Train Reaction
Falco 25 Train Reaction is a game that will make your brain work at its maximum capacity! Find all the numbers from 1 to 25, located randomly on the playing field, in the minimum time. Falco 25 Train Reaction is a great way to improve your concentration and reaction speed. Can you complete the task in 15 seconds?
Link
mfG
Trapped
Kein Support per PN/Mail
