Audio Split & Trim 3.4.4.40 & SuperDucks
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Audio Split & Trim 3.4.4.40
If you can hear it you can record it with Audio Split & Trim. Audio splitter and audio joiner Audio Split & Trim records MP3 from any device installed on your system.
Audio Split & Trim records to high quality MP3 and you can immediately edit mp3 files with Audio Split & Trim built-in audio editor, audio trimmer, audio splitter, and audio joiner.
Audio Split & Trim supports 12+ different audio formats including MP3, WMA, M4A, OGG, WAV, FLAC, CAF, and more... You can cut, copy, paste, trim, split, join, and apply audio effects to audio. The program supports multiple segments what gives you the option to split and trim audio file in multiple parts at once. It is a real time saver not found on most mp3 audio editors.
You can apply audio effects to audio such as volume gain or reduction, noise reduction, reverb, equalization, pitch, and many more...
Main features:
1. Easy to use mp3 audio recorder.
2. Record directly to high quality mp3. No conversion.
3. Cut, copy, paste, split, trim, and join audio files with built-in audio mp3 editor.
4. Fade-in, fade-out, reverb, noise reduction, equalization, and 20+ audio effects.
5. Convert to 12+ different formats.
Extra features:
1. Real-time audio spectrum frequency analyzer.
2. Ability to trim multiple segments at once.
3. Ability to split multiple segments at once.
Audio Split & Trim is a complete audio capture, editing, and converting suite.
Link
Game Giveaway of the day — SuperDucks
Welcome to SuperDucks – a dynamic 2D platformer-puzzle game! Choose one of seven unique ducks with special abilities and embark on an exciting journey through dark and vibrant levels. Solve puzzles, overcome obstacles, and enjoy the unique style of each tour!
Link
mfG
Trapped
Kein Support per PN/Mail
