lcd4linux:driver_astusb
Inhaltsverzeichnis
ASTUSB driver
This driver supports the DIY „AST USB-LCD“ interface: an ATtiny2313 that connects a HD44780 based text display to USB. Schematics and firmware can be found at http://ast.m-faq.de/USB-LCD/USB-LCD.htm.
The interface is detected by its USB vendor and product ID (0x03eb / 0x7a53). Displays with two controllers (more than two rows and more than 20 columns) are supported.
Display Section
Display <name> {
Driver 'ASTUSB'
Size <string>
Bus <string>
Device <string>
Backlight <0|1>
Icons <number>
asc255bug <0|1>
Parameters
| Driver | 'ASTUSB' |
| Size | <columns>x<rows> e.g. '20×4'. Required. |
| Bus | Bus name as displayed during USB scan (e.g. '003'). Only required when using more than one interface. |
| Device | Device name as displayed during USB scan (e.g. '004'). Only required when using more than one interface. |
| Backlight | initial backlight state (0 = off, 1 = on) |
| Icons | Number of user-defined chars reserved for Icons (default: 0) |
| asc255bug | set to 1 if you don't get solid blocks in bars, but an inverted P |
Plugins
The driver provides the following function:
| LCD::backlight(n) | switch the backlight on (n = 1) or off (n = 0) |
Example
This is the entry from lcd4linux.conf.sample:
Display ASTUSB {
Driver 'ASTUSB'
Size '20x4'
Backlight 1
Requirements
libusb (0.1) is needed. The driver is selected at build time with –with-drivers=ASTUSB.
lcd4linux/driver_astusb.txt · Zuletzt geändert: von 127.0.0.1
