Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_dpf
DPF
Display Section
Display <name> {
    Driver       'DPF'
    Port         '<string>'
    Font         '<string>'
    Orientation  <number>
    Backlight    <number>
    Foreground   color in hex
    Background   color in hex
    Basecolor    color in hex
Parameters
Driver'DPF'
PortNormally 'usb0'. If you have more than one dfp connected: 'usb0„ ist the first, 'usb1' the second dpf, etc.
FontDefault: '6×8'; but all fonts sizes are available.
Orientationthe dpfs logical orientation. For dpfs with height != width: 0 = landscape, 1 = portrait, 2 = reverse landscape, 3 = reverse portrait. For dpfs with height = width: 0 = standard, 1 = rotate 90° CW, 2 = rotate 180°, 3 = rotate 90° CCW. Note: physical orientation does not matter. Rotation is done in the driver.
BacklightSet the dpfs backlight/brightness. Values: 0-7 (0 = off, 7 = max).
ForegroundFont color.
BackgroundBackround color.
Basecolor…
Examples
Display dpf {
   Driver 'DPF'
   Port 'usb0'
   Font '8x10'
   Orientation 0
   Backlight 7
   Foreground 'ffffff' #white
   Background '000000' #black
   Basecolor 'ff0000' #red
Plugins
The driver provides the following function:
LCD::backlight(n)set the backlight/brightness of the dpf to n (0..7, 0 = off, 7 = max)
Goodbye message
When LCD4Linux is stopped, the driver clears the display and looks for the file /tmp/lcd/goodbye.
  • If the file exists, its first line is displayed and the file is removed. This also happens when the splash screen is disabled.
  • If the file does not exist, 'goodbye!' is displayed, but only if LCD4Linux was started with -s.
echo "Rebooting..." > /tmp/lcd/goodbye
Requirements
The driver is self-contained. No external headers/libraries needed.
lcd4linux/driver_dpf.txt · Zuletzt geändert: von 127.0.0.1
