Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_ili9486_fb
ili9486_fb driver
This driver supports SPI TFT displays with an ILI9486 controller on Orange Pi and Raspberry Pi boards. It does not talk to the controller itself, it writes to the Linux framebuffer device that is provided by the kernel modules fbtft and fb_ili9486.
The driver was tested on an Orange Pi PC2 with a 3.5 inch SPI TFT (480×320, RGB). The touchscreen of these displays is not supported.
Display Section
Display <name> {
    Driver       'ili9486_fb'
    Port         <string>
    Size         <string>
    Bpp          <string>
    Font         <string>
    Foreground   <color>
    Background   <color>
    Basecolor    <color>
Parameters
Driver'ili9486_fb'
Portframebuffer device of the display, e.g. '/dev/fb1'. Required.
Sizesize of the display in pixels, specified as <width>x<height>. Required, the maximum is '480×320'.
Bppbits per pixel of the framebuffer. Required, the maximum is 16. The pixels are written as RGB565.
Fontfont size, specified as <width>x<height>. Default is '6×8', every size from 6×8 upwards is possible (the built-in 6×8 font is scaled).
Foregroundcolor of active pixels (RRGGBBAA or RRGGBB), default is opaque black '000000ff' (see Colors for details)
Backgroundcolor of inactive pixels (RRGGBBAA or RRGGBB), default is transparent 'ffffff00' (see Colors for details)
Basecolorcolor of the virtual backlight (RRGGBB), default is white 'ffffff' (see Colors for details)
A Backlight entry (0..10) is accepted, but has no effect: the driver has no way to control the backlight.
Example
This is the entry from lcd4linux.conf.sample:
Display ILI9486_FB {
    Driver 'ili9486_fb'
    Port '/dev/fb1'
    Size '480x320'
    Bpp '16'
    Font '24x42'
    Basecolor '000000'
    Foreground 'ffffffff'
    Background '00000000'
Plugins
LCD::backlight(n)registered, but without function (see above). Returns 0 for n = 0, otherwise 1.
Goodbye message
When LCD4Linux is stopped, the driver clears the display and looks for the file /tmp/lcd/goodbye.
  • If the file exists, its first line is displayed and the file is removed. This also happens when the splash screen is disabled.
  • If the file does not exist, 'goodbye!' is displayed, but only if LCD4Linux was started with -s.
The line must end with a newline character (as written by echo), otherwise the file is treated as empty.
Requirements
  • kernel modules fbtft and fb_ili9486, so that the display shows up as a framebuffer device
  • no external libraries
The driver is selected at build time with –with-drivers=ILI9486_FB.
lcd4linux/driver_ili9486_fb.txt · Zuletzt geändert: von 127.0.0.1
