lcd4linux:driver_lcd-linux
Inhaltsverzeichnis
LCD-Linux
This driver supports the HD44780 kernel driver LCD-Linux.
Note that this project is called LCD-Linux, not LCD4Linux. Nevertheless there's a LCD4Linux-driver for LCD-Linux
For instructions about compiling, configuring and installing LCD-Linux see their project page.
Display Section
Display <name> {
Driver 'LCD-Linux'
Size <string>
UseBusy <0|1>
Bus4Bit <0|1>
asc255bug <0|1>
Icons <number>
Parameters
| Driver | 'LCD-Linux' |
| Size | <columns>x<rows> e.g. „16×2“; overwrites the size specified when loading the kernel module |
| UseBusy | 0 (don't use Busy-Flag checking, default) or 1 (use Busy-Flag checking) |
| Bus4Bit | 0 (8 bit bus, default) or 1 (4 bit bus); overwrites the bus width specified when loading the kernel module |
| asc255bug | set to 1 if you don't get solid blocks in bars, but an inverted P (the Portishead syndrome |
| Icons | Number of user-defined chars reserved for Icons (default: 0) |
Example
Display LCD-Linux {
Driver 'LCD-Linux'
Size '20x2'
UseBusy 0
asc255bug 0
Icons 1
lcd4linux/driver_lcd-linux.txt · Zuletzt geändert: von 127.0.0.1
