lcd4linux:driver_lcdterm
Inhaltsverzeichnis
LCDTerm driver
Display Section
Display <name> {
Driver 'LCDTerm'
Model 'generic'
Port <string>
Speed <number>
Size <string>
asc255bug <0|1>
Icons <number>
Parameters
| Driver | 'LCDTerm' |
| Model | 'generic' |
| Port | serial device the display is attached to (e.g.'/dev/ttyS2') |
| Speed | the baud rate from the display must match this value. Possible values are 1200, 2400, 4800, 9600, 19200, 38400 and 115200 |
| Size | <columns>x<rows> e.g. „16×2“ |
| asc255bug | set to 1 if you don't get solid blocks in bars, but an inverted P (the Portishead syndrome |
| Icons | Number of user-defined chars reserved for Icons (default: 0) |
Example
Display LCDTerm {
Driver 'LCDTerm'
Port '/dev/tts/0'
Speed 19200
Size '20x4'
asc255bug 0
Icons 1
lcd4linux/driver_lcdterm.txt · Zuletzt geändert: von 127.0.0.1
