Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_mdm166a
MDM166A driver
This driver supports the Futaba MDM166A, a graphic vacuum fluorescent display with 96×16 pixels and a row of symbols (play, pause, record, mail, WLAN, volume). It is connected via USB (vendor ID 0x19c2, product ID 0x6a11). The driver was written by Andreas Brachold.
Display Section
Display <name> {
    Driver      'MDM166A'
    Size        <string>
    Font        <string>
    Brightness  <number>
    Inverted    <0|1>
Parameters
Driver'MDM166A'
Sizesize of the display in pixels, specified as <width>x<height>, default is '96×16'
Fontfont size, specified as <width>x<height>, default is '6×8'
Brightnessinitial brightness (dimming level of the display), 0..2
Invertedset to 1 to invert the display
Plugins
The driver provides the following function:
LCD::brightness(n)set the brightness to n (0..2)
Symbols (GPOs)
The symbols of the display are controlled as GPOs, see the GPO widget for how to use them. A value greater than 0 switches the symbol on.
GPOSymbol
GPO1Play
GPO2Pause
GPO3Record
GPO4Message (envelope, without the inner @)
GPO5Message @
GPO6Mute
GPO7WLAN (tower base)
GPO8WLAN strength 1 of 3
GPO9WLAN strength 2 of 3
GPO10WLAN strength 3 of 3
GPO11Volume (the word)
GPO12 .. GPO25Volume level 1 .. 14
Example
This is the entry from lcd4linux.conf.sample:
Display MDM166A {
    Driver   'MDM166A'
    Brightness  1
    Inverted   0
    Size      '96x16'
    Font      '6x8'
Widget GPO_Mute {
    class 'GPO'
    expression file::exist('/tmp/muted')
    update 500
Layout Default {
    GPO6 'GPO_Mute'
Requirements
libusb-1.0 is needed (not the old libusb 0.1 most other USB drivers use). The driver is selected at build time with –with-drivers=MDM166A.
lcd4linux/driver_mdm166a.txt · Zuletzt geändert: von 127.0.0.1
