Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_noritake
Noritake driver
This driver can be used for various Noritake displays. Currently, the only display available is the following :
Noritake GU128x32-311
(Please see in the attachement section the links for the documentation of the display and the wiring).
The current driver does not yes support all the functions of the display, in particular, only the text mode is supported at this time, the graphic mode is beeing developped, no ways to set the brightness, no bars in text mode (But the graphic mode will support it natively).
Display Section
Display <name> {
    Driver    'Noritake'
    Model     <string>
    Port      <string>
Parameters
Driver'Noritake'
Modelsee below
Portparallel device the display is attached to (e.g.'/dev/parport0', or /dev/partport/0 with devfs)
Models
The driver supports only one model now : GU311. It has to be specified. The size for the display is fixed to 4 lines and 21 columns in text mode.
ModelSize
GU3114×21
Examples
Display Noritake {
    Driver   'Noritake'
    Model    'GU311'
    Port     '/dev/parport0'
Plugins
No plugins yet.
lcd4linux/driver_noritake.txt · Zuletzt geändert: von 127.0.0.1
