Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_phanderson
PHanderson driver
This driver supports the PHAnderson serial-to-HD44780 controller.
Display Section
Display <name> {
    Driver    'PHAnderson'
    Port      <string>
    Speed     <number>
    Size      <string>
    Blackligth <number>
    Bootscreen <string>
    WRITE     <number>
    READ      <number>
    BOOT      <number>
Parameters
Driver'PHAnderson'
Portserial device the display is attached to (e.g.'/dev/ttyS2')
Speedthe baud rate from the display must match this value. Possible values are 2400, 9600 and 19200
Size<columns>x<rows> e.g. „16×2“
Blacklightinitial backlight brightness, 0..255
Bootscreeninitial message at LCD power on
WRITEwrite eeprom execution timing in millisecondes, default is 170ms
READread eeprom execution timing in millisecondes, default is 10ms
BOOTwrite boot message execution timing in millisecondes, default is 300ms
Example
Display LCDTerm {
    Driver   'PHAnderson'
    Port     '/dev/tts/0'
    Speed     19200
    Size     '24x2'
    Blackligth 100
    Bootscreen '123456789012345678901234ABCDEFGHIJKLMNOPQRSTUVWX'
    WRITE     170
    READ      10
    BOOT      300
Plugins
The driver provides the following functions. Note the spelling: both the config entry and the function are called Blacklight, not Backlight.
LCD::blacklight(n)set the backlight brightness to n (0..255)
LCD::bootscreen(text)store text as the message the display shows at power on. The text is distributed over the rows of the display. An empty string disables the boot screen.
lcd4linux/driver_phanderson.txt · Zuletzt geändert: von 127.0.0.1
