lcd4linux:driver_serdisplib
Inhaltsverzeichnis
serdisplib
This driver controls all displays supported by the serdisplib project.
The serdisplib supports displays connected to parallel port, serial port (RS232), I2C and USB (depending on the displays). Not all versions of serdisplib supports every connection type, consult their webpage.
For details about serdisplib itself, supported displays, connections and wiring, installation and so on go to the serdisplib project page.
Display Section
Display <name> {
Driver 'serdisplib'
Model <string>
Port <string>
Options <string>
Font <string>
Contrast <number>
Backlight <0|1>
Reverse <0|1>
Rotate <0..3>
Foreground <color>
Background <color>
Basecolor <color>
Parameters:
| Driver | 'serdisplib' |
| Model | display model/driver for serdisplib, e.g. 'OPTREX323' |
| Port | port where the display is connected in serdisplib notation, e.g. 'PAR:/dev/parports/0' or 'USB:060c/04eb' |
| Options | serdisplib options, e.g. 'WIRING=1;INVERT=YES' |
| Font | font size, specified as <width>x<height> (only '5×8' and '6×8' supported at the moment) |
| Contrast | initial contrast value, 0..10 |
| Backlight | initial backlight state, 0 (off) or 1 (on) |
| Reverse | initial display inversion, 0 (normal) or 1 (inverted) |
| Rotate | initial display rotation, 0 (0 normal) to 3 (270 degree) |
| Foreground | color of active pixels (RRGGBBAA or RRGGBB), default is opaque black '000000ff' (see Colors for details) |
| Background | color of inactive pixels (RRGGBBAA or RRGGBB), default is transparent 'ffffff00' (see Colors for details) |
| Basecolor | color of virtual backlight (RRGGBB), default is white 'ffffff' (see Colors for details) |
Plugins:
The driver provides the following functions:
| LCD::contrast(n) | sets the display contrast (0..10) |
| LCD::backlight(n) | sets the backlight state, 0 (off) or 1 (on) |
| LCD::reverse(n) | sets the display inversion, 0 (normal) or 1 (inverted) |
| LCD::rotate(n) | sets the rotation, 0 (0 normal) to 3 (270 degree) |
Example
Display Optrex323 {
Driver 'serdisplib'
Model 'OPTREX323'
Port 'PAR:/dev/parports/0'
Options ''
lcd4linux/driver_serdisplib.txt · Zuletzt geändert: von 127.0.0.1
