Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_st2205
st2205
Information
Check out the picframe project to get more information. There is a hacked firmware available, so you digital photoframe can be used as LCD4Linux display.
Resolution: 128×128 Pixels (also 320×240)
Quite cheap
updated libst2205
How to compile
You need the st2205 library and header files installed. They are available on the picframe wiki site.
Plugins
The driver provides the following function:
LCD::backlight(n)switch the backlight on (n = 1) or off (n = 0)
Example config
Config-Example:
Display st2205u {
    Driver     'st2205'
    Port       '/dev/sda'
    Font       '6x8'
    Foreground 'ffffff'
    Background '000000'
    Basecolor  '000000'
Widget OS {
    class 'Text'
    expression '*** '.uname('sysname').' '.uname('release').' - st2205 driver by Sprite ***'
    width 21
    align 'M'
    speed 500
    update tick
    Background '008000'
    Foreground 'ffffff'
Widget CPU {
    class  'Text'
    expression  uname('machine')
    prefix 'CPU '
    width  9
    align  'L'
    update tick
    Background 'FFFFFF00'
Widget RAM {
    class  'Text'
    expression meminfo('MemTotal')/1024
    postfix ' MB RAM'
    width  11
    precision 0
    align  'R'
    update tick
Widget Busy {
    class 'Text'
    expression proc_stat::cpu('busy', 500)
    prefix 'Busy'
    postfix '%'
    width 10
    precision 1
    align 'R'
    update tick
    Foreground 'ffffff'
Widget BusyBar {
    class 'Bar'
    expression2 proc_stat::cpu('system', 500)
    length 21
    direction 'E'
    update tack
    Foreground 'ffffff'
    Background '00000080'
    BarColor0 '8f8fff'
    BarColor1 'ff8f8f'
Widget Load {
    class 'Text'
    expression loadavg(1)
    prefix 'Load'
    postfix loadavg(1)>1.0?'!':' '
    width 10
    precision 1
    align 'R'
    update tick
    Foreground 'ffffff'
Widget LoadBar {
    class 'Bar'
    max 2.0
    length 21
    direction 'E'
    update tack
    Foreground 'ffffff'
    BarColor0 '8f8fff'
    BarColor1 'ff8f8f'
Widget Disk {
    class 'Text'
    # disk.[[:lcd4linux:rw]]blk return blocks, we assume a blocksize of 512
    # to get the number in kB/s we would do blk*512/1024, which is blk/2
    # expression (proc_stat::disk('.*', 'rblk', 500)+proc_stat::disk('.*', 'wblk', 500))/2
    # with kernel 2.6, disk_io disappeared from /proc/stat but moved to /proc/diskstat
    # therefore you have to use another function called 'diskstats':
    expression diskstats('hd.', 'read_sectors', 500) + diskstats('hd.', 'write_sectors', 500)
    prefix 'disk'
    postfix ' '
    width 10
    precision 0
    align 'R'
    update tick
    Foreground 'ffffff'
Widget DiskBar {
    class 'Bar'
    #expression  proc_stat::disk('.*', 'rblk', 500)
    #expression2 proc_stat::disk('.*', 'wblk', 500)
    # for kernel 2.6:
    expression2 diskstats('hd.', 'write_sectors', 500)
    length 21
    direction 'E'
    update tack
    Foreground 'ffffff'
    BarColor0 '8f8fff'
    BarColor1 'ff8f8f'
Widget Eth0 {
    class 'Text'
    expression (netdev('eth0', 'Rx_bytes', 500)+netdev('eth0', 'Tx_bytes', 500))/1024
    prefix 'eth0'
    postfix ' '
    width 10
    precision 0
    align 'R'
    update tick
    Foreground 'ffffff'
Widget Eth0Bar {
    class 'Bar'
    expression  netdev('eth0', 'Rx_bytes', 500)
    expression2 netdev('eth0', 'Tx_bytes', 500)
    length 21
    direction 'E'
    update tack
    Foreground 'ffffff'
    BarColor0 '8f8fff'
    BarColor1 'ff8f8f'
Widget Uptime {
    class 'Text'
    expression uptime('%d days %H:%M:%S')
    width 20
    align 'R'
    prefix 'Up '
    update 1000
Widget Bgnd {
    class 'Image'
    file 'bgnd.png'
    reload 0
    update 0
    inverted 0
    visible 1
Display 'st2205u'
Layout mylayout {
    Row01.Col01 'OS'
    Row02.Col02 'CPU
    Row02.Col10 'RAM
    Row04.Col01 'Busy
    Row05.Col01 'BusyBar
    Row06.Col01 'Load'
    Row07.Col01 'LoadBar'
    Row08.Col01 'Disk'
    Row09.Col01 'DiskBar'
    Row10.Col01 'Eth0'
    Row11.Col01 'Eth0Bar'
    Row16.Col01 'Uptime'
    Layer 2 {
	X1.Y1 'Bgnd'
Layout 'mylayout'
Variables {
    tick 500
    tack 200
    minute 60000
lcd4linux/driver_st2205.txt · Zuletzt geändert: von 127.0.0.1
