lcd4linux:driver_usb2vfd
Inhaltsverzeichnis
USB2VFD driver
This driver supports the 40×2 „USB2VFD“ vacuum fluorescent displays that are sold (e.g. on Aliexpress) as status displays for AIDA64. They show up as a serial port.
In AIDA64 these displays are configured as Matrix Orbital LK displays, but they are only roughly compatible:
- contrast and brightness commands are ignored
- the display freezes on every command it does not like; only 'go home' and 'go to position' work
- there are no user-defined characters
- nothing is displayed until the whole display buffer has been filled
The driver therefore keeps both lines in a buffer and always sends the complete 2×40 characters.
Display Section
Display <name> {
Driver 'USB2VFD'
Port <string>
Speed <number>
BarChar <number>
Parameters
| Driver | 'USB2VFD' |
| Port | serial device the display is attached to (e.g. '/dev/ttyUSB0') |
| Speed | baud rate of the serial port, default is 19200 |
| BarChar | ASCII code (1..255) of the character that is used for the filled part of bars. Default is 127 (0x7F), which is a full block on these displays. |
The size is fixed to 40×2, a Size entry is not evaluated.
Widgets
Only the Text and the Bar widget are available. As the display has no user-defined characters, there are no icons, and a bar can only be filled in steps of whole characters.
Special characters of the display:
| | | shown as °C |
| \x7F | full block |
Example
Display USB2VFD {
Driver 'USB2VFD'
Port '/dev/ttyUSB0'
Speed 19200
Requirements
No external libraries. The driver is selected at build time with –with-drivers=USB2VFD.
lcd4linux/driver_usb2vfd.txt · Zuletzt geändert: von 127.0.0.1
