lcd4linux:driver_vnc
Inhaltsverzeichnis
VNC driver
This driver creates a VNC Server, using libvncserver.
Example
Display VNC {
Driver 'VNC'
Font '6x8'
Port '5900'
Xres '320'
Yres '140'
Bpp '4'
Maxclients '2'
Buttons '4'
Keypadxofs '40'
Keypadyofs '70'
Keypadgap '10'
Keypadcol '8745877'
Osd_showtime '2000'
Password 'password'
Maxfps '22'
HttpDir '/home/code/LibVNCServer-0.9.7/classes'
HttpPort '80'
Parameters
| Driver | 'VNC' |
| Font | font size, specified as <width>x<height> (only '5×8' and '6×8' supported at the moment, default is '5×8') |
| Port | listening port of the VNC server |
| Xres | X resolution of the VNC display |
| Yres | Y resolution of the VNC display |
| Bpp | bits per pixel of the VNC display, valid values are 1,2 and 4 |
| Maxclients | how many clients can connect to the vnc server |
| Buttons | use keypad buttons, valid range is 0-6 |
| Buttonsize | size of a keypad button in pixels, valid range is 8-256, default is 50 |
| Keypadxofs | X offset position of the on screen display |
| Keypadyofs | Y offset position of the on screen display |
| Keypadgap | Gap in pixels between Keys, default is 10. (Earlier versions of this page called the entry Keypadygap; the driver reads Keypadgap.) |
| Keypadcol | Color (decimal format, baaaaaad) for the keypad frame |
| Osd_showtime | Time in ms to display the OSD keypad |
| Password | Adds an *unsecure* password option. If you need security, use SSH! |
| Maxfps | Limits the internal fps rate of the driver. -1 disable this feaature |
| !HttpDir | |
| !HttpPort | listening port of the VNC HTTP server. This option will be ignored if the HttpDir option is missing! |
Keyboard
The defined buttons are drawn on the VNC display after you clicked on the screen. The keys are named „Up“, „Down“, „Left“, „Right“, „Commit“ and „Cancel“.
Compile
You need libvncserver, zlib and libjpeg to compile this driver.
Advanced Example, with keypad support
Variables {
tick 500
tack 100
minute 60000
currline 1
Display vnc {
Driver 'VNC'
Font '6x8'
Port '5900'
Xres '320'
Yres '140'
Bpp '4'
Maxclients '2'
Buttons '4'
Keypadxofs '40'
Keypadyofs '70'
Keypadcol '8745877'
Osd_showtime '4000'
Widget keyup {
class 'Keypad'
position 'up'
state 'pressed'
expression currline = currline-1
Widget keydown {
class 'Keypad'
position 'down'
state 'pressed'
expression currline = currline+1
Widget KeypadTest {
class 'Text'
expression currline
prefix 'keypad ['
update 1000
width 20
Widget ImageTest {
class 'Image'
file 'tux.png'
update 1000
visible 1
inverted 1
Layout L40x2 {
Row3 {
Col5 'OS'
Row4 {
Col5 'CPU'
Row7 {
Col5 'BarTest'
Row8 {
Col5 'KeypadTest'
Layer 2 {
X1.Y1 'ImageTest'
Keypad1 'keyup'
Keypad2 'keydown'
Display 'vnc'
Layout 'L40x2'
lcd4linux/driver_vnc.txt · Zuletzt geändert: von 127.0.0.1
