Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_vuduo2
vuduo2 driver
This driver supports the colour front display of the VU+ Duo2 set-top box. It is a sibling of the vuplus4k driver.
The display geometry is fixed in the driver: 400×240 pixels, 16 bits per pixel.
Display Section
Display <name> {
    Driver       'vuduo2'
    Port         <string>
    Font         <string>
    Foreground   <color>
    Background   <color>
    Basecolor    <color>
Parameters
Driver'vuduo2'
PortLCD device of the box. This entry is required, there is no default.
Fontfont size, specified as <width>x<height>. Default is '6×8', every size from 6×8 upwards is possible (the built-in 6×8 font is scaled).
Foregroundcolor of active pixels (RRGGBBAA or RRGGBB), default is opaque black '000000ff' (see Colors for details)
Backgroundcolor of inactive pixels (RRGGBBAA or RRGGBB), default is transparent 'ffffff00' (see Colors for details)
Basecolorcolor of the virtual backlight (RRGGBB), default is white 'ffffff' (see Colors for details)
A Backlight entry (0..10) is accepted, but has no effect: setting the brightness is switched off in the source of this driver („currently not supported“).
Example
The device name below is the one commonly found on VU+ images, check it on your box.
Display VUDUO2 {
    Driver     'vuduo2'
    Port       '/dev/dbox/lcd0'
    Font       '12x16'
    Foreground 'ffffff'
    Background '00000000'
    Basecolor  '000000'
Plugins
LCD::backlight(n)registered for compatibility with the vuplus4k driver, but does not change the brightness (see above). Returns 0 for n = 0, otherwise 1.
Goodbye message
When LCD4Linux is stopped, the driver clears the display and looks for the file /tmp/lcd/goodbye.
  • If the file exists, its first line is displayed and the file is removed. This also happens when the splash screen is disabled.
  • If the file does not exist, 'goodbye!' is displayed, but only if LCD4Linux was started with -s.
The line must end with a newline character (as written by echo), otherwise the file is treated as empty.
Requirements
The driver is self-contained, no external libraries are needed. It is selected at build time with –with-drivers=VUDUO2.
lcd4linux/driver_vuduo2.txt · Zuletzt geändert: von 127.0.0.1
