Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_cfg
Inhaltsverzeichnis
cfg plugin
This plugin allows reading of values from lcd4linux.conf.
Functions
cfg(key, …)read a parameter from the config file
This function has a variable number of parameters, all parameter are concatenated together with a dot ('.') and the resulting string is used as a key into the config file.
Example
cfg('Display')
cfg('Layout:Default', 'Row1', 'Col1')
lcd4linux/plugin_cfg.txt · Zuletzt geändert: von 127.0.0.1
