Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_cpuinfo
cpuinfo plugin
This plugin provides an interface to the /proc/cpuinfo file.
Functions
cpuinfo(key)parse /proc/cpuinfo and return the value of the line beginning with <key>
The key parameter does not have any fixed values, but is taken as a search key into the /proc/cpuinfo file. Common values are cpu MHz or cache size. Do a cat /proc/cpuinfo to see which keys are supported on your system.
lcd4linux/plugin_cpuinfo.txt · Zuletzt geändert: von 127.0.0.1
