Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_dvb
DVB (digital video broadcast) plugin
This plugin allows reading the status of a DVB card.
Functions
dvb(key)gather status from the DVB frontend and return certain values
Valid keys are:
signal_strengthsignal strength
snrsignal/noise ratio
berblock error rate
ucbuncorrected blocks
Note that this plugin always opens the first frontend on the first DVB card (which is /dev/dvb/adapter0/frontend).
Example
Widget DVB {
    class      'Text'
    expression  dvb('signal_strength')*100
    prefix     'DVB'
    width       9
    precision   1
    align      'R'
    update      500
Widget DVB_Bar {
    class       'Bar'
    expression2  dvb('snr')
    min          0
    max          1
    length       10
    direction   'E'
    update       200
lcd4linux/plugin_dvb.txt · Zuletzt geändert: von 127.0.0.1
