Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_isdn
ISDN plugin
This plogin provides information about the ISDN subsystem.
Note that this plugin has been developed and tested with Linux-2.4, isdn4linux and the HiSax-driver. I can't tell if Linux 2.6 and/or the new mISDN is supported. Any feedback on this would be appreciated!
Functions:
isdn::info(key, channel)parse /proc/isdninfo
isdn::cps(channel)return ISDN throughput (character per second)
This function parses /dev/isdninfo and returns the value of key for a specified channel (which is the column from /dev/isdninfo).
There are no predefined keys, but the portion before the first colon of every line from /dev/isdninfo is used verbatim. Take a look at your /dev/isdninfo for keys supported on your system. Common keys are 'usage', 'flags' or 'phone'.
isdn::cps(channel, delay)
This function returns the average throughput of the ISDN channel (prefixed by 'i' (input/received) or 'o' (output/transmitted). If you omit the channel number (which means specify only 'i' or 'o'), the sum over all available channels is returned. The throughput is averaged over delay milliseconds. Using 500 msec delivers good values.
Note that this function is available only if the file linux/isdn.h has been available at compile time!
Examples
Sorry, no examples :-)
I don' use ISDN anymore, so I cannot test it, and therefore don't have any sample configurations or widgets. It would be great if someone could provide one or another example here!
lcd4linux/plugin_isdn.txt · Zuletzt geändert: von 127.0.0.1
