Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_list
#!html
<h1 style="text-align: left; color: red">
This Plugin is not part of the current lcd4linux. This wiki entry was created for discussion about a plugin prototype.
<br><br>
</h1>
Plugin List
1. Description
Plugin List allows to configure lists that can be modified while runtime.
2. Configuration
The basic structure in the config-file looks like this:
Plugin List {
    active 1
    List1 {
        value1 'red'
        value2 'green'
        value3 'blue'
        value4 'alpha'
    List2 {
        value1 1
        value2 'two'
        value3 3
    List3 {
„active 1“ activates the plugin. If it has not been activated all of its functions will return -1.
The plugin must contain at least 1 list. List may be empty (no value). Lists and values have to be numbered serially starting with 1.
Plugin parameters:
activeSet to 1 to activate plugin, otherwise the plugin won't work and all of its functions return -1.
List parameters:
name*must be unique, default: 'List1' for List1 …
limit*Maximal number of values this list may contain 0..1000, overwritten with initial number of values if above, default: 10
*optional
====== functions3. Functions =
All functions return -1 on error (e.g. plugin not active, wrong config, wrong indexes, name not found).
As usual on lcd4linux indexing starts with 1.
FunctionargsDescription
list::add( lst*, idx, val ) 3 add value to list, idx from 1..size+1, returns -1 on error, else 0
list::delete( lst*, idx ) 2 deletes value number idx from list
list::get( lst*, idx ) 2 returns value number idx in list lst
list::find( lst*, val ) 2 returns idx of value val in list lst or -1 if not found
list::limit( lst* ) 1 maximal number of values in list lst
list::set( lst*, idx, val ) 3 sets value number idx to val, returns -1 on error, else 0
list::size( lst* ) 1 current number of values in list lst
* lst may contain the name or the index of the list
lcd4linux/plugin_list.txt · Zuletzt geändert: von 127.0.0.1
