lcd4linux:plugin_pop3
Inhaltsverzeichnis
POP3 plugin
This plugin allows to check your mail on a POP3 mail server.
Note: Response time depends on your net connection so, if you do not have a good latency line, you shouldn't use this pluging because it could hang lcd4linux while POP3 plugin is waiting the mail server response.
Functions
| POP3check(n) | return the number of mails in the account number <n> |
Configuration example
You can define up to three different POP3 accounts. If port entry is missing, 110 will be used as default.
Plugin POP3 {
server1 'mail.server.foo'
user1 'JohnSmith'
password1 'topsecret'
server2 'free.mail.foo'
user2 'MadJohnny'
password2 'ImMad'
server3 'pop.myisp.foo'
user3 'John2005'
password3 'idontknow'
Widget examples
You can check the three accounts defined above with three widgets
Widget mailSmith {
class 'Text'
expression POP3check(1)
prefix 'Mail'
width 7
precision 0
align 'R'
update 30000
Widget mailJohnny {
class 'Text'
expression POP3check(2)
prefix 'Johnny'
width 9
precision 0
align 'R'
update 30000
Widget mailJohn {
class 'Text'
expression POP3check(3)
prefix 'Work'
width 7
precision 0
align 'R'
update 30000
Or you can use one widget to check more than one account
Widget mailSmith {
class 'Text'
expression POP3check(1)+POP3check(2)
prefix 'Mail'
width 7
precision 0
align 'R'
update 30000
lcd4linux/plugin_pop3.txt · Zuletzt geändert: von 127.0.0.1
